What did you do to the X today? - Page 501 - Ford Truck Enthusiasts Forums
  #7501
Old 04-30-2012, 12:58 PM
xbox73 xbox73 is offline
xbox73 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by ComputerCowboy View Post
Also I don't have a jack that could lift my truck with the 8" lift on it... so I'd need roadside assistance for a flat anyway.
I also have an 8" lift on my X. As a solution for a jack that could lift my X, I bought whichever bottle jack had the maximum extended height from Harbor Freight. I think it was either the 12 ton one or the 20 ton one. That was almost high enough, but not quite, so I went to Home Depot & had them cut a 1" thick 8' x 1' plank of wood into 8 separate 1' x 1' squares. By stacking a number of these 1" thick 1' x 1' squares, you can build a thick enough base for the bottle jack to get you enough extra height so the neck of the bottle jack can reach the axle tube & lift it off the ground.
Someone in a previous post suggested a high-lift jack, but unless you have heavy duty metal offroad front & rear bumpers and/or rock sliders, there isn't really anything heavy duty enough for the foot of the jack to sit under that is suitable for supporting that kind of weight. IIRC, you can buy an attachment for the foot of a high lift jack that will fit into a receiver hitch, so that may work if you have receiver hitches both front & rear. Edit: However, since both the front & rear of the X likely weigh more than the tongue weight rating of the receiver hitch, I'm not sure how wise this is, though it may work in a pinch.
I would also imagine that a high-lift jack might work well for changing a tire on an open-deck car trailer as most car trailers have a heavy duty metal frame around the outside.
Anyway, a couple of thick planks of wood as a base, and a cheap properly rated bottle jack with suitable extended height seem like a reasonably priced practical solution.
Last edited by xbox73; 04-30-2012 at 01:03 PM. Reason: Added point regarding receiver hitch tongue weight rating
  #7502
Old 04-30-2012, 01:40 PM
HeathJohnson HeathJohnson is offline
HeathJohnson is gaining momentum as a positive member of FTE.HeathJohnson is gaining momentum as a positive member of FTE.
I love those seats and console. Beautiful!
  #7503
Old 04-30-2012, 01:41 PM
BuiltFordTough!'s Avatar
BuiltFordTough! BuiltFordTough! is offline
BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.
Quote:
They are 2,000% more comfortable then my 2002 seats were.
  #7504
Old 04-30-2012, 02:18 PM
archtaan's Avatar
archtaan archtaan is offline
archtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputation
Quote:
Originally Posted by TrdLtly View Post
Tim, Did you get one of these yet? DTS Articles - HFCM Water Separator Drain Plug Upgrade
I would use a 5 gallon bucket to prop up as close to the bottom of the frame as possible. That would catch about 99% of the fuel and the only thing that go bathed was the one hand undoing the plug. Not to bad that way.
Thanks for the link! Just using a hex driver, a few extensions, a swivel and usually I can clear the member and 4wd housing. Light went out today, still gonna check it though.
  #7505
Old 04-30-2012, 02:37 PM
TrdLtly's Avatar
TrdLtly TrdLtly is offline
TrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputation
Quote:
Did you install them yourself? Where are the pictures and installation thread? It HAS to be around here somewhere... (that is a hint)
  #7506
Old 04-30-2012, 02:40 PM
archtaan's Avatar
I just don't get it with all these people not doing build threads.....
  #7507
Old 04-30-2012, 02:43 PM
TrdLtly's Avatar
Quote:
I had to get up off the floor. I fell out of my chair from laughing so hard. I realize that was the point, but from all people Tim. That was hilarious. Thanks.
  #7508
Old 04-30-2012, 02:44 PM
yes I installed them very easy do I didnt think It needed its own thread
  #7509
Old 04-30-2012, 02:46 PM
archtaan's Avatar
Yeah I know.....
That was the irony!
I have all my pics ready at least! Need to dig out my notes to match up with the pics..
  #7510
Old 04-30-2012, 03:13 PM
Installed 2010 F350 crew cab front seats and console:
Had to move the heated seats control from being on the dash to on the seat:
Interesting, I may be interested in doing this at some point in the future, since the leather on the seat back of my 2000 X's driver seat has now started to separate around the 'Limited' (or whatever) stitching that is high on the seat back.
I was planning on maybe getting my old seats recovered, but if the 2010 seats are really that much more comfortable, I may reconsider. Are they really that much more comfortable, and if so, in what way?
Also, are the seats (except for the relocation of the heater controls) a direct plug in (i.e. bracketing, seat rails & electrical connectors etc.)? Is it necessary to use the new center console with the new seats, or just something that you opted to do to update the interior? And lastly, where did you get the updated seats from, and how much did they cost?
  #7511
Old 04-30-2012, 03:25 PM
The leather is softer as is the foam. The new seats do not have arm rests built in so u need the console or a center seat. I removed the plastic part of the harnus on my old seat and just rearanged the wires to the correct order. They bolted right in. I got them from eBay cost 600 shipped.
  #7512
Old 04-30-2012, 03:28 PM
TrdLtly's Avatar
See... write-up! This forum is built on other's experience. Share the wealth... of knowledge.
  #7513
Old 04-30-2012, 05:03 PM
Sunline Fan's Avatar
Sunline Fan Sunline Fan is offline
Excursion Fleet Manager
Sunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputation
Got the dreaded water in fuel light today. Gonna pull the plug on the frame mounted filter and see if it has a bunch of junk on it. Just changed both filters about 1000 miles ago. I hate doing that frame mounted filter. Pulling the little plug is worse. Can you say diesel bath?
Oh Tim, you're bringing back memories of the shower of antifreeze I got when I pulled the rear coolant lines to the rear A/C and heat. Turns out all the coolant wasn't drained after all...
  #7514
Old 04-30-2012, 05:12 PM
Interesting, did the eBay ad say how many miles were on the seats? My dad's F-450 seats are much firmer than my '02, but comparable to the '05. I guess the '02 just has more miles/use to soften up the foam.
The arm rest issue is a big deal for me personally. For where I put the seat (higher up), the console is much too low and away from me. Since I don't get to drive it much, when I do, I usually take a jacket or blanket and bunch it up between me and the console to simulate an arm rest. On the other hand, for whatever reason my dad likes the seat as far back and as low as he can, so he's content with where the console is at then.
  #7515
Old 04-30-2012, 06:26 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Originally Posted by GIGGER View Post
Yes LEDs are great, I hear they are making them for the house now too, they just screw in to a light bulb socket
Yep, I have three in my main bathroom.
So where is the how-to thread with pictures?
Heh, ya beat me to it.
Well it does! A thread like this needs to be in the Tech Folder thread.
Stewart
Replacing the rear speakers in a 2010 Regular Cab propellerhead Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 14 06-22-2016 06:34 PM
78/79 RestoMod Raleigh1 1978 - 1996 Big Bronco 682 03-18-2016 02:29 PM
MY '03 EXCURSION...WITH '08 FRONTEND. DaXman Excursion - King of SUVs 30 07-03-2015 06:38 PM
New Member..New Owner.. RussEx Excursion - King of SUVs 10 02-09-2015 10:05 PM
2012 excursion released! Snowseeker Excursion - King of SUVs 5 10-27-2011 01:48 PM
Tags
20x10, bouncing, excursion, f250, f350, ford, fuel, hydro, wpt943
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
