What did you do to the X today?
#7472
The 2000 X received a new water pump today, the lifetime warranty one i put on 4 years ago started leaking. New upper and lower rad hoses as well as the hose from the bottom of the rad to the bottom of the tank, new thermostat as well. New antifreeze also, its been in there for 10 years and still tested good with the Fleet Guard test strips, I have been running Fleet Guard ES Complete in all my Equipment (Peterbilts, John Deere, Ford Power Strokes) for years, the cooling system was as clean as it could be, no electrolysis, no pitting, no scale and very clean. It is also getting a new aluminum t-stat housing from www.dieselsite.com
While i was in there i rebuilt the oil cooler also, it showed signs on external leaking, very glad i did this, after removing it and dismantling it, the inner o-rings were very hard, so hard that when i used a pic to remove them they just broke!
That's what i did to my X today!
It's ready for another 200'000 miles now!
#7474
#7475
So far yes... I need to run it through 4 or 5 more heat cycles on the gears before I start piling miles on it. Then after 500 miles we'll change the diff fluid, clean out any bits and bobs that the new gears lost during break in and then I'll hook her up to the camper and then I'll really know if it was worth all the work, but so far,
#7476
#7477
Received 5,139 Likes
on
#7478
#7480
on
#7483
#7485
