What did you do to the X today? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-10-2010, 09:27 AM
DRM's Avatar
DRM DRM is offline
DRM is starting off with a positive reputation.
Quote:
Originally Posted by idahof350 View Post
Saturday I installed a K&N intake kit and switched it over to Royal Purple. Sunday I re-tuned the truck, new slightly less aggressive timing maps, an economy tune, and messed with the shift firmness and the shift schedule. Really happy with the new tune...
Which programmer?
  #32
Old 08-11-2010, 01:31 PM
idahof350 idahof350 is offline
idahof350 is starting off with a positive reputation.
Quote:
Originally Posted by DRM View Post
Which programmer?
I have a 4-position SCT chip in the truck, I just burn the programs to it as I make changes. I like the ability to swith programs on the fly. I have a performance tune and an economy tune, and then I have each of those with either a stock shift schedule or a custom shift schedule. It takes me 5-6 minutes to program the chip when I modify the tunes, and then I can switch tunes while driving if I want, no down time loading programs.
Update on the trip too, averaged 13.60 over 1174 miles traveled, up as high as 7200ft and back down as low as 1000ft again, and the V-10 is awesome. We opted to take the V-10 Excursion instead of the 6.0L F-350 for this trip, and I'm pretty happy with how it has performed. The only time I missed the diesel was passing trucks up 6% grades, the V-10 is a little shy on torque and has to kick down and wind out the revs. This thing would clean my old 460 F-350's clock.
  #33
Old 08-11-2010, 07:59 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
i scored some factory foglights on CL for $20! thinking about installing them now. just gotta order some HIDs for them. might install my 55w HID kit also.
  #34
Old 08-11-2010, 09:44 PM
slenser slenser is offline
slenser is gaining momentum as a positive member of FTE.
I took the truck in for an a/c evac and fill. It was a bit low, but they found no leaks. It blows colder now, so my trip to TX tomorrow will be nice and cool.
  #35
Old 08-11-2010, 09:56 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Finished my drivers side lower door rust repair, hooked up the scanner to check if there were any old stored codes, pulled the boat home in preparations for my first ever pulling two trailers at the same time in two days.
  #36
Old 08-11-2010, 10:00 PM
fuelman fuelman is offline
fuelman is gaining momentum as a positive member of FTE.
Put Rancho 9000 shocks on it today,and worked on freeing up the manual hubs. All working better. New Bridgestone Revo tires are supposed to be in tomorrow. Hope to get them on Friday,285/75R16. Next week will put in my Vcodes and alignment,thinking of putting in the rear 3in blocks I got from the salvage yard. Will see how it sits after springs are in. Oh yea changed the oil too...
  #37
Old 08-12-2010, 06:59 AM
hkaiser83 hkaiser83 is offline
hkaiser83 is gaining momentum as a positive member of FTE.hkaiser83 is gaining momentum as a positive member of FTE.
Quote:
You're going to need that a/c! It's hot as hell down here in Houston!
  #38
Old 08-12-2010, 08:01 AM
I need it here too with the heat index being around 110-115 these last few days!
  #39
Old 08-12-2010, 06:23 PM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
I drove it again today like I stole it. Man I love the sound of the v10 and the now crisp gear changes with the 5star tunes.
  #40
Old 08-18-2010, 05:20 PM
Snowseeker's Avatar
Scraped down and POR'ed the receiver today.
Now how to take care of this?
  #41
Old 08-18-2010, 09:48 PM
Excurvelle's Avatar
Excurvelle Excurvelle is offline
Excurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud of
Did you top coat over the POR15?
  #42
Old 08-18-2010, 10:09 PM
howler4x4's Avatar
howler4x4 howler4x4 is offline
howler4x4 is gaining momentum as a positive member of FTE.howler4x4 is gaining momentum as a positive member of FTE.
Swapped out the rusty steel rear diff cover for the OEM late model finned aluminum cover, plus $70 worth of Motorcraft 75W-140 synthetic and a tube of Dana friction modifier.
  #43
Old 08-18-2010, 11:00 PM
AlaskanEx's Avatar
on my way home today i made sure my speed limiter was gone i'm happy to say she held 105 no prob!
  #44
Old 08-19-2010, 08:53 AM
Snowseeker's Avatar
Quote:
Nope, not to worried about fade.
  #45
Old 08-19-2010, 09:26 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Quote:
Once I get back from this business trip, I'll installing my 2008 diff cover and some Royal Purple
Replacing the rear speakers in a 2010 Regular Cab propellerhead Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 14 06-22-2016 05:34 PM
78/79 RestoMod Raleigh1 1978 - 1996 Big Bronco 682 03-18-2016 01:29 PM
MY '03 EXCURSION...WITH '08 FRONTEND. DaXman Excursion - King of SUVs 30 07-03-2015 05:38 PM
New to me 2000 Ex jayjjcc Excursion - King of SUVs 12 02-07-2012 02:18 AM
Here is why you want fuses & fusible links in your wiring ctubutis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 12-17-2011 11:28 PM
Tags
20x10, bouncing, excursion, f250, f350, ford, fuel, hydro, wpt943
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
