What did you do to the X today?
Well, using your common core math (bahahahahahaha) then you are in error, it was a minimum of 140 Atlanta fans. Had to be, you few were doing the chop whenever y'all saw each other.
On second, thought call me David you SF Philistine
Stewart
Well, the Ex just finished the 12+ hour haul from Salt Lake City, and I am now sitting at home.
The Ex ran perfectly the whole trip. I only once saw the temps jump into the 220 range and the EGT climb above the 1100k mark, and that was when I was flogging it up a steep grade in eastern Oregon in 90+ weather.
The Ex seems to be reborn, and it is about time, as my wallet is once again tapped out
Now, tomorrow should be a complete overhaul of the Ex, vacuum and a wash top to bottom. Man is she a dirty girl at the moment...
On another note, anyone have any experience with trans codes??
https://www.ford-trucks.com/forums/1...rong-here.html
I hate drum brakes
I put on my new rotors, pads and power stop calipers yesterday. I could not get the parking brake adjusting screw to back off. It took me five hours to do the first side and less than an hour for the second. I still need to bleed them. I hope I can get done tonight. Did I mention I hate drum brakes?
I also tried to find the 1/2 to 3/8 fittings to install my 6.0 transmission cooler with no luck.
I found mine at Home Depot, the best I could do locally. I had to do it with 2 pieces ( at Lowes it would have taken 3 pieces ) like Dave suggested. The 1/2 inch was a female that threaded onto the 3/8 male. Sorry.... I forget what size the pipe thread was. I couldn't find adapters individually on Amazon when I ordered the cooler.
