What did you do to the X today?
Hey - don't take the side of the STATE OF ARIZONA on this - I am trying to beat a expensive ticket. Again, here in Arizona they give tickets if you "pull doubles" UNLESS the center towed vehicle has a "fifth wheel"...and again...of course there is no such thing as a "fifth wheel"...I have a 3500 series Duramax turbo-diesel equipped like that...just, as you & I both note..a big ball hitch located in the center of the pick-up bed. No wheels in the system !
When you want to "quote" a post just use the "Quote" button in the lower right corner of the post you want to quote, that's why it's there. And please stop using all of the "equals signs" (====), I think it might be those special characters that are screwing up nearly every one of your posts here, makes reading your posts very hard as what you quote and post look the same.
Not busting your stones (this time....), just trying to help.
And yes, "fifth wheels" really do exist, good luck trying to convince AZ that they don't. Did you know that you can't wear "brake shoes" on your feet either?
Originally Posted by hav24wheel
O the hell. I was wrong! I had to walk out to the pickup, that's what mine says too. Guess I remembered the ranch part n thought ranch hand.
If you want I can take a pic of the mounting brackets.
The third coat of paint just went on, loading it up to take over to my uncles shop so I can fab some brackets up later this afternoon. Like I said, you would be a saint if you wouldn't mind snapping a quick pic or two of your brackets.
Cheers,
Nate
STOP BOTHERING ME. I AM VERY BUSY. YOU HAVE A FRIGGEN CLUE HOW HARD IT IS TO GET BONDO TO STICK TO THE RUST ON MY "mInt" EXCURSION'S 'A' COLUMN........ I MAY HAVE TO GIVE UP AND SELL IT AS A CONVERTIBLE.....
YES - I HAVE A FIFTH WHEEL - IT IS ALSO CALLED 'SPARE TIRE'
on
Sooner or later it just becomes impossible to get Baja out of your Ex and you have to disassemble it for a through cleaning.
Going to shampoo the carpets and if they don't clean up to my liking I will order up a new rug to go with the driver seat rebuild.
Funny how ruined they look with just 20 minutes worth of work taking the seats out.
At least, then bigger tires then new shocks then new wheels then remove glue stains and then and then...and then put your deleted steps back on and then
Just putting longer shackles on will affect your alignment in the front and your driveline angle in the rear.
In the front longer shackles will add negative caster which may effect, wandering, death wobble , steering return to center and tire scrub.
In the back it will roll your pinion angle up and may cause a driveline vibration.
Be sure to get an alignment and have your angles correct up front and have your pinion angle checked if you notice a vibration.
You want us to see this.
My eye leaps right to this.
Just a heads up,
I added 2.5" lift shackles in late 2010 shortly after getting my current Ex. The truck drives exactly the same as it did stock, absolutely no strange tire wear or handling issues since putting them on. I never had an alignment done, I have no wandering issues with this truck ( my 2004 Ex was a whole different story ) to this day i'm still running them 45K miles later with half those miles being locked in 4x4 during the winter.
Yes it's the cheap option, but it does the trick when needed. I do plan on upgrading the springs within the next year and doing it "right".
I cleaned the turbo and put it all back together. I've been battling this excessively loud PowerMax turbo for a while now and new cold and hot side boots, clean turbo vanes etc. thus far nothing has resolved the noise problem. Details on my quest over on the 6.0 forum.
Here are a couple of pics and a test drive video.
