What did you do to the X today? - Page 11 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #151
Old 11-11-2010, 04:11 PM
hhcobra hhcobra is offline
hhcobra is gaining momentum as a positive member of FTE.
Flushed the power steering pump with 1.5 quarts of Mobile syn. ATF. Brake pedal came up about 1 inch and pump quit whinning[sp]. How much were the new mats?
  #152
Old 11-11-2010, 04:20 PM
CrzHelm's Avatar
CrzHelm CrzHelm is offline
CrzHelm is gaining momentum as a positive member of FTE.CrzHelm is gaining momentum as a positive member of FTE.
just did my ball joints. wasnt too bad at all. glad i did it my self. thanks to those guys for taking the time to post those balljoint write ups everything went smooth.
  #153
Old 11-11-2010, 04:46 PM
slenser slenser is offline
slenser is gaining momentum as a positive member of FTE.
Quote:
You flushed your power steering pump and it affected the brake pedal?
  #154
Old 11-11-2010, 07:44 PM
Snowseeker's Avatar
Snowseeker Snowseeker is online now
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
My brakes improved quite a bit after the flush as well.
  #155
Old 11-11-2010, 07:47 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
just got my lift shackles in, may go install them...debating.
  #156
Old 11-11-2010, 11:28 PM
1NiceHarley's Avatar
1NiceHarley 1NiceHarley is offline
1NiceHarley is gaining momentum as a positive member of FTE.1NiceHarley is gaining momentum as a positive member of FTE.
Greased the front steering locations. Lubed the drivers window. Removed an old phone system that was in the truck.
tomorrow: going to look at the rear door switch
Saturday: going to get the windows tinted.
  #157
Old 11-12-2010, 01:37 AM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
topped off my rear diff fluid.
  #158
Old 11-12-2010, 08:09 AM
twisstedex's Avatar
twisstedex twisstedex is offline
twisstedex is starting off with a positive reputation.
Quote:
if im not mistaking the desle trucks run on hydro boost so yes the ps fluid would efect the brakes....at least thats how my rollbacks are set up and one of them is the international with the 7.3....i hate hydro boost bec if the truck isnt runig or u loose ur belt u have no brakes.very scarry situation to be in trust me been there
  #159
Old 11-12-2010, 08:11 AM
Skip1970's Avatar
actually you have 3 or so pushes of the pedal left, that what the small canister is on the hydroboost its a reserve
  #160
Old 11-12-2010, 08:57 AM
Snowseeker's Avatar
And it is pretty much the same for gas trucks with vacuum boosters. If the motor quits running you only have a couple pumps till the vacuum is gone.
I don't mind the hydro boost. at least it eliminates the belt driven vacuum pump that used to be on older diesels. I am surprised ford still uses a vacuum pump for heater controls. Just do away with all that and use stepper motors like everyone else.
  #161
Old 11-12-2010, 12:47 PM
Quote:
Quote:
Huh, I guess you do learn something new everyday!
  #162
Old 11-12-2010, 04:14 PM
mark996's Avatar
mark996 mark996 is offline
mark996 is gaining momentum as a positive member of FTE.mark996 is gaining momentum as a positive member of FTE.
Well, in the past week I've had a lot of things done..
2 COP's changed
Plugs and boots changed
Oil Changed
Oil Filter, Fuel Filter changed, Air Filter changed
And, to hopefully end the week of things failing...last night the Alternator crapped out, so this morning I ended up changing it out. All is well, things are good in the hood again.
  #163
Old 11-13-2010, 02:28 PM
EMC V10 X's Avatar
EMC V10 X EMC V10 X is offline
EMC V10 X is starting off with a positive reputation.
I replaced the rear brake calipers, rotors and pads, Used Napa calipers (and caliper brackets), Autozone Rotors, and Hawk pads. I also flushed the system. She stops WAY better now. I also fixed the door ajar switch in the back liftgate. It was much easier than expected. Then I took apart and lubed the front autolocking hubs. Next weekend or the weekend after I will attempt the front brakes.
  #164
Old 11-13-2010, 05:26 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Today my truck mind ****ed me....
For last few months, injector #1 started having issues where it seemed mechanically the injector was done. I ran some Rotella T6 and it seemed to fix it, but thought I would pull the valve covers anyhow.
Well...
I pulled both covers checked the harness and connectors, unplugged the harness while the truck was running to verify, and everything checks out. I put the truck back together take it for a drive and then the same problem happens again...
I planned on changing the injector, but decided against it since it decided to run better and get better mileage. Now I'm kicking myself wishing I would've just changed the inejctor and just let that be that. Electronically it's fine and passes a buzz test when it wanted to, but mechanically it can't decide whether it wants to work or not...it's getting changed for sure next weekend.
  #165
Old 11-13-2010, 07:12 PM
59CRL's Avatar
59CRL 59CRL is offline
59CRL is gaining momentum as a positive member of FTE.59CRL is gaining momentum as a positive member of FTE.
I just started doing some mods on mine, added a Billet Grille and a Brush Guard. Im going to add some fog lights to the Brush Guard next.
78/79 RestoMod Raleigh1 1978 - 1996 Big Bronco 682 03-18-2016 02:29 PM
MY '03 EXCURSION...WITH '08 FRONTEND. DaXman Excursion - King of SUVs 30 07-03-2015 06:38 PM
New Member..New Owner.. RussEx Excursion - King of SUVs 10 02-09-2015 10:05 PM
Here is why you want fuses & fusible links in your wiring ctubutis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 12-18-2011 12:28 AM
2008 GMC Sierra Red Star Ford vs The Competition 30 08-04-2006 11:44 AM
Tags
20x10, bouncing, excursion, f250, f350, ford, fuel, hydro, wpt943
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
