What did you do to the X today? - Page 1001 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #15001
Old 04-04-2013, 02:37 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
I will wear gloves now and than when I have to work or more around real slimy parts or vehicles. I don't mind getting a little dirty but when you have to dig threw gunk to even see the bolts you need to take out I will wear gloves.
That and for any chemical work.
  #15002
Old 04-04-2013, 02:50 PM
59CRL's Avatar
59CRL 59CRL is offline
59CRL is gaining momentum as a positive member of FTE.59CRL is gaining momentum as a positive member of FTE.
I fixed my super sloppy steering wheel. With the vehicle turned off you can turn the steering wheel a good 3 inches to each side.... this tells me the power steering gear box is shot or needs to be severly adjusted. While driving down the road it takes skill to keep the truck on the road. So.... I loosedned up the nut on the steering gear box and turned the allen screw in a good 3 full turns. Now the wheel is a little tighter but almost no play to each side. Maybe 1/2 at the most. Looks like I can put off a new steering gear box for a while....
  #15003
Old 04-04-2013, 02:57 PM
az_r2d1 az_r2d1 is offline
az_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud of
Quote:
Try flushing the fluid as well. Improved the steering feel on my EX a great deal. Very easy to do.
  #15004
Old 04-04-2013, 04:30 PM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
Did this about 2 weeks back, but just no time to sit at a pc and post pictures.
New 50" single row front mounted LED light and my new back up, extra lighting facing back, 10" LED bar.
switches mounted in upper console.
  #15005
Old 04-04-2013, 04:41 PM
Atc210 Atc210 is offline
Atc210 is gaining momentum as a positive member of FTE.Atc210 is gaining momentum as a positive member of FTE.
Light bar looks cool, do you have a night shot of how bright it is?
  #15006
Old 04-04-2013, 04:45 PM
sammie0126's Avatar
sammie0126 sammie0126 is offline
sammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputation
Got Up pipes installed and bolted down tight (I hope) and everything from the CAT back in place and on jack stands. The CAT needs trimmed about another inch and the CAT hangers will work perfectly. Found 2 hanger issues from the CAT through to tail pipe I need to resolve.
#1 The rear CAT to Muffler hanger does not line up with the connection between the rear CAT and muffler and the hanger Banks sends is a clamp/hanger combo. On this one (1st pic below) I think all I do is use the hanger where it needs to be to fit the hanger in the frame which is about 2 inches south of the actual pipe joint, then add a 3" exhaust clamp over the joint.
#2 The tail pipe hanger is not going to work, it comes in the from the wrong direction and the spring is in the way. Thinking on this one (2nd pic below) I need to cut that hanger off, then cut the stock hanger off the original tail pip (3rd pic below) and weld it onto the tail pipe.
Any suggestions or easier fixes welcome.
  #15007
Old 04-04-2013, 04:53 PM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
Looks good, Don't clamp it completely tight until you have it all fitting like you want, then cinch it down.
  #15008
Old 04-04-2013, 05:00 PM
AzPatMan's Avatar
AzPatMan AzPatMan is offline
AzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud of
For pic 1 - I'd just bust out the dremmel and cut off wheel.
Cut the weld for the hanger and just re-weld it to the proper line up.
Otherwise, just go to lowes/home-depot and get some bar-stock and bend to your needs and weld it to replace the clamp/hanger combo.
Pic 2, I'd do the same and just re-use the old hangers after welding on (if you still have them laying around.)
  #15009
Old 04-04-2013, 05:13 PM
sammie0126's Avatar
Pic 1 the hanger on the pipe isn't welded to it, it's a combination clamp and hanger in one it bolts on, I can move it back to line up with the hanger but then the joint where the CAT meets the muffler won't have a camp over it. Was thinking just slide it back and clamp it down where it needs to be to fit the hanger in the frame, then just add another 3" clamp over the joint.
On the tailpipe, yes I do have the old tailpipe hanger (pic 3) and I'm thinking I just need to cut it off the old pipe, and put it on the new one where I need it to be.
  #15010
Old 04-04-2013, 05:19 PM
AzPatMan's Avatar
Gotcha,
From the point of view - looked like the bar for the hanger is just welded to the clamp,
which could have been cut away and separated without effecting the clamp itself...
Quote:
Yep. That's why you keep the old parts around until the project is done - just in case you need to reuse part of it!
  #15011
Old 04-04-2013, 05:21 PM
sammie0126's Avatar
Gotcha,
Ok got you - you know that might work - I didn't get what you meant. I will look at it and see. If not no big deal to get an additional clamp at the parts store in the morning.
  #15012
Old 04-04-2013, 10:03 PM
truck7575's Avatar
truck7575 truck7575 is offline
truck7575 has a good reputation on FTE.truck7575 has a good reputation on FTE.
Your pics rock! Only thing would makem better is a squeaky clean X
Quote:
Originally Posted by AlaskanEx View Post
well, i drove the excursion today..beautiful day its in the 40s and sunny. supposed to snow this weekend/next week though.
sold two trucks today so that was awesome! we grabbed some food and went for alittle drive to enjoy the sunset.
  #15013
Old 04-04-2013, 10:05 PM
truck7575's Avatar
I've been using the nitrile dipped cloth gloves... They are fairly cheap and last a long time... I get 10 pairs at SAMs club for $6
  #15014
Old 04-04-2013, 10:09 PM
truck7575's Avatar
Go back over your diagram... Mine didnt line up either and I had one of the pipes in wrong place... Two were very similar and I had them backwards... On another note you could just buy another 4 inch exhaust clamp and use it at the joint then slide the hanger clamp back and tighten it in the right place so it lines up... Hope it helps!
  #15015
Old 04-04-2013, 10:13 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
Quote:
i know i wish! supposed to snow this weekend/next week. she wont be clean or see her 20" summer wheels/tires till late april. i think the deadline to have my studded snow tires off is May 1st. i plan on giving her a really good detail inside/out once it warms up and i can find my hose under 4ft of snow pack on my yard LOL
78/79 RestoMod Raleigh1 1978 - 1996 Big Bronco 682 03-18-2016 02:29 PM
MY '03 EXCURSION...WITH '08 FRONTEND. DaXman Excursion - King of SUVs 30 07-03-2015 06:38 PM
New Member..New Owner.. RussEx Excursion - King of SUVs 10 02-09-2015 10:05 PM
Here is why you want fuses & fusible links in your wiring ctubutis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 12-18-2011 12:28 AM
2008 GMC Sierra Red Star Ford vs The Competition 30 08-04-2006 11:44 AM
Tags
20x10, bouncing, excursion, f250, f350, ford, fuel, hydro, wpt943
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
