1988 F450 7.3L diesel charging system - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-07-2010, 06:57 PM
98Ranger2.5 98Ranger2.5 is offline
98Ranger2.5 is starting off with a positive reputation.
Hi Im helping out a buddy trace out his charging system problem. he has a 1988 ford F450 diesel flatbed tow truck. he already put in a new Alt. regulator, batterys. still does not charge. im looking to see if anyone can help out with a wiring diagram for the charging system.
thanks in advance
Old 08-07-2010, 07:08 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
Did you check the battery fuse?
Old 08-07-2010, 07:16 PM
HUM did not know there is one Where would it be located
Old 08-07-2010, 11:43 PM
jc8825's Avatar
It is in the dash fuse panel in the SD trucks, but in some cars it is under the hood. It is a larger fuse 60A or higher.
Old 08-08-2010, 11:29 AM
thanks JC but thiss truck is a 88 it does not have any big fuse like that. all the fuseable links though were checked. you wouldnt happen to know what the 4 pins on the voltage regulator go to.
2006 F250 no AC PAf250 Cooling, Heating, Ventilation & A/C 43 10-01-2011 06:54 PM
help finding low side port bcronk Cooling, Heating, Ventilation & A/C 5 06-09-2011 04:03 AM
Batteries dead over night, Alternator overcharging batteries, confused Nyxlee 1987 - 1996 F150 & Larger F-Series Trucks 10 01-26-2011 10:07 AM
Will a zf 5 speed trans mount to my 400M? Phoenix2769 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-03-2010 09:47 AM
Charging the Camper Battery Docdor Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 6 10-17-2009 11:36 PM
Tags
1988, 2002, 450, 73, charge, diagram, diesel, duty, f450, flatbed, ford, powerstroke, problem, super, tow, truck, turbo, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
