1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
rear end axel tube sliped help
Old 08-07-2010, 02:45 PM
dukie1877's Avatar
dukie1877
dukie1877 is offline
I have a 03 f-250 psd 4x4 I bought the truck from an auction wrecked and fixed almost everything except this. One of the axel tubes that go into my rear pumpkin has twisted a little and now the blocks the leaf springs sit on are different. It has made my rear end slightly point tward the drivers side and my truck cat walks down the road. I had the frame measured and its square. I noticed my U-Bolts were at different angles from eachother. I tried using big pipe wrenches while the the rear end was still on the truck to twist it back and weld it. It wouldent move so I dropped the rear end out and have it on my welding table. It has 3 shear pins or somthing that have broke off and came out easily they are near the pumpkin. Im guessing these three points on each side have something to do with holding these tubes strait? I have having a really hard time with this and could use some help. I called a local rear end shop and they have never heard of it and dont know how to fix it. Let me know if you have any Ideas Thank you for all your help in the past you guys have saved me alot of time and money and i really appreciate it.
Duke
Old 08-07-2010, 04:04 PM
be250's Avatar
be250
be250 is offline
hey get a good used rear end.
Old 08-07-2010, 05:20 PM
2000V10USER's Avatar
2000V10USER
2000V10USER is offline
Those slug welds are generally not work repairing....just find a good used axle and get it on the road.
Old 08-08-2010, 07:03 AM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
Axle housing is junk, fine a entire used rear end.
Old 08-08-2010, 07:57 AM
44dwarf's Avatar
44dwarf
44dwarf is offline
Geting the rear square again in not easy add to that the housing has undergone major stressing and impact. I'd doubt if the tube is straight.
If you realy have to do it your self try making a jig like I use in this article for my race cars.
How to Manufacture a Rear Axle Housing for a Dwarf Car / Modlite Race Car
however you'll have to reset the gears as they don't pull out the front like the toyotas or the old 9inch fords.
44
Old 08-08-2010, 08:01 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
I agree, you probably already have more time and energy in what you've done so far than just replacing the whole rear axle with a used one.
Sam
LSO1123
01-05-2014 06:30 AM
thx2net
1997 - 2003 F150
01-01-2013 01:04 PM
CSBaldwinAssoc
05-25-2007 09:11 AM
Quick Reply: rear end axel tube sliped help
