Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-14-2003, 09:52 AM
Ron_Hanson Ron_Hanson is offline
Ron_Hanson is starting off with a positive reputation.
Question 1997 Expedition E.B. spare key programming
I am trying to program a spare transponder key for my remote start system in my expedition, I have followed the instructions that have been posted here for this year of truck. Every time I try to put the new key in after the original key my theft light flashes constantly. I've tried it many times and nothing. If anyone has any info on this it would be much appreiciated.
thanks
  #2 (permalink)
Old 02-14-2003, 03:58 PM
adelyser adelyser is offline
adelyser is starting off with a positive reputation.
Are you sure you have the correct key? 99+ models use a different key. Otherwise, you basically insert old key, turn to run, turn off and within 5 seconds, insert new key and turn to run. Light goes out and you are done.
__________________
Aaron D.
'94 EB Bronco 4x4, 351W, E4OD w/ B&M Shift Improver
'97 Expedition XLT 4x4, 5.4L, E4OD w/ B&M Shift Improver, Accel COP's
'88 F-250 SC Diesel 4x4, 7.3 NA, 4.10's
  #3 (permalink)
Old 02-15-2003, 07:23 PM
Rtpjunior Rtpjunior is offline
Rtpjunior is starting off with a positive reputation.
For the 99's you need the 2 ORIGINAL keys to program a new key. If you don't have them, you have to go to a dealership, or a locksmith with the Ford NGS machine.................
  #4 (permalink)
Old 03-08-2003, 01:08 AM
jrahn jrahn is offline
jrahn is starting off with a positive reputation.
How about a 97 with one key? can I program 1 more myself or do I need the dealer?
__________________
97 Exp 4X4 5.4
K&N Air Filter (ported airbox)
Gibson 3" SS Cat-Back Exhaust
Edelbrock IAS Shocks
Hypertech PowerProgrammer & T-Stat
Optima Yellow Top
Viper Remote Start
-More to come-
  #5 (permalink)
Old 03-08-2003, 09:33 AM
Dave54ca Dave54ca is offline
Dave54ca is starting off with a positive reputation.
I also had to get another key for my 1997 Expeditions remote starter. If I recall correctly, you will need both original keys in order to program the third. If you do not have both then the dealer will have to do it for you.
If you do have both keys I'm sure the dealer will explain the procedure to you.
  #6 (permalink)
Old 03-08-2003, 05:48 PM
jk349 jk349 is offline
jk349 is starting off with a positive reputation.
I don't know about the remote start and what mods needed for remote start to work, but on the '98 you do not need two keys to program a second pats key!
In order to program a second pats key you simply put the original key in the ignition switch and turn the key to the run position (do not start the motor), the theft light will come on then after a few seconds go off, now the computer is ready to program second key, turn the switch off and insert the new key and turn the switch back to the run position (again do not start) within 15 seconds. Now the new key is programmed. Turn the switch back to off remove the key and wait 20 seconds to start with the new key to check it.
I don't know if the '97 is different.
JK
  #7 (permalink)
Old 03-09-2003, 07:13 PM
I picked up the second key at Ford Sat. and got into a debate with the parts guy over the entire programming issue.
He swore that the techs had to do it, and it only takes about 30 minutes.... I bet him a soda that I could program the new key in front of his eyes, and he accepted.
You should have seen his expression when I introduced the new key!
In with the original, wait 10 seconds, in with the copy, wait 10 seconds, start the truck.
I enjoyed my Mountain Dew.
To confirm:
97 - 98 need only one key to add a copy, 99 + need to have a pair.
However the Viper 150ESP auto starter requires at least two keys to properly enable the auto start function.
How to do that programming, I have no idea....
__________________
97 Exp 4X4 5.4
Optima Yellow Top
Viper Remote Start
-More to come-
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
