Runs good until warms up - Ford Truck Enthusiasts Forums
Old 08-06-2010, 10:50 PM
MNbandit MNbandit is offline
MNbandit is starting off with a positive reputation.
My truck recently has been running weird. When I first start my truck when it's completly cool it runs fine. After about five minutes it starts to run rough and buck. It does idle high at first when I start it. Could this be the coolant temp sensor? The iac and tps are new.
Old 08-06-2010, 11:24 PM
f-150_1993's Avatar
f-150_1993 f-150_1993 is offline
f-150_1993 is starting off with a positive reputation.
Well when my ECT sensor was bad it made my truck
have trouble starting after warmed up.
I don't know about making it run rough when warm though.
Maybe the Air Temp Sensor.
Old 08-07-2010, 09:16 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Pull the codes so you know if there is a sensor problem or not, don't just blindly guess.
Running rough when first started 95schauf 1994.5 - 1997 7.3L Power Stroke Diesel 5 02-15-2015 08:47 AM
scangauge reading for FICM sarnott140 6.0L Power Stroke Diesel 18 03-29-2011 02:36 PM
truck battery not charging? bluescrew 1999 - 2003 7.3L Power Stroke Diesel 16 04-08-2010 03:13 PM
help pls!!! jimwilsonmasonry 1994.5 - 1997 7.3L Power Stroke Diesel 35 02-20-2009 06:24 AM
Starts but then dies when released to run fordflaresides General Automotive Discussion 2 01-18-2006 10:09 PM
Tags
1993, 1996, 2007, 64, chevy, engine, f350, good, powerstroke, rough, run, runs, suburban, truck, untill, up, warms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
