Headlight switch wiring diagram - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 08-06-2010, 10:11 PM
97ExpGuy 97ExpGuy is offline
97ExpGuy is gaining momentum as a positive member of FTE.
Need a headlight wiring diagram or someone to tell me what each colored wire controls on my 97 at the pin connector.
Old 08-09-2010, 05:09 PM
I haven't received a response for my post. Maybe I wasn't clear on what I needed so I posted a couple of pictures. Basically, I need to know what each wire does (powers) below for a '97 model.
Reason is I read the article here on the boards titled "Whiter Whites, Brighter Brights" (where you wire the headlights to the battery for improved light output) and thinking about doing the modification. However, I don't want to cut the factory harness up. If possible I'd remove the wires at the headlight switch plug and run the new wires from there to the relays. Hopefully that makes sense. Automotive electrical isn't my strong point.
Old 08-10-2010, 07:17 AM
c_hohensee c_hohensee is offline
c_hohensee is starting off with a positive reputation.
This is for a 98 but here are the color codes, they are likely the same.
Smaller grey plug C244
W/B Fog lamps on indicator
Grey Plug C245
DB/W Power (hot in park or head)
W/R Lamps on output to GEM
BK/PK Ignition (hot on acc)
BR Exterior lamps output
T/W Power (hot at all times)
O/LG Dome lamp switch
Black Plug C246
BK Ground
Y Fog lamp switch
LB/BK Radio illumination
DB/O Power (hot at all times)
R/Y Headlamps output
LB/R Switch illumination circuit
Old 08-10-2010, 09:00 AM
Grey Plug C245
Black Plug C246
BK Ground
Y Fog lamp switch
Thanks a million Craig!
Headlight wiring diagram Eddillard79 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 07-31-2015 11:23 AM
96 f150 headlight switch Michael1181 1987 - 1996 F150 & Larger F-Series Trucks 2 02-08-2011 03:46 AM
Ground wire on headlight switch? ghunt 1987 - 1996 F150 & Larger F-Series Trucks 2 01-01-2008 06:45 PM
1997 F350 diesel wiring diagram RVSupply 1999 to 2016 Super Duty 6 12-18-2007 08:51 AM
Headlight switch wiring diagram 78f250lj 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-03-2002 06:21 PM
Tags
86, 97, diagram, f150, f350, fog, ford, head, headlight, light, rear, switch, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
