Trans Shifting and Turbo Surge?
i have 2 questions for you all i hope i did not leave something out. all so no codes that the SC can read.
1.I have a SC 1705 programmer hope to get a PHP soon, but if i get on it hard the trans well slam in to all of the gears when shifting it dose it more in the high HP mode, is this good or bad. when i changes it well rack the hole truck and very load.
2. i can make my turbo surge when just taking of slightly fast and when i push it some at highway speed, should it surge that easy?
see sig for modes.
Thanks
see sig for modes.
Thanks
Has it always done it with the SC or did it just start
Can you program the SC like you have a shift kit and use stock trans tuning .That would lower the line pressure.I don't have any experience with the SC but the hypertec you can
There was a post about EBP sensor making the trans shift goofy and also brake light bulbs
No, I mean't the shifter ****, the OD select, on or off. Not much more to add but custom tunes you can't go wrong. I still got my SC for code reading, for fity bucks keep that. It's no AE but its worth its weight in gold to read codes..I think PHP is running a sale right now, you might want to check out their web-site..DP just came out with a new chip, F-8 I believe, check theirs out too.
Tampa250
07-15-2011 11:17 PM
