SLAM DUNK. Diablo Predator For Powerstroke Diesel - 4 Program Tuner
on
<h3>Diablo Predator For Late 1999 - 2003 7.3L Power Stroke Diesel Fords!</h3>
<p align=justify>
<img src="http://motorhaven.autoanything.com/Web_store/Images/diablode.jpg" align=left><b>The Diablo Predator was engineered to raise hell!</b>
<img src="/Web_store/Images/ford_predator_2.jpg" align=right>
<p align=justify>
<font face="helvetica, arial, helvetica" size=2>
The Predator is the <b>premier</b> tuning product for the Power Stroke!
The Predator provides 4 levels of high performance flash tuning, full text OBD-II diagnostic
capabilities and <b>real-time</b> data monitoring of sensor inputs.
The Predator is a tunable performance module, which utilizes flash technology
to reprogram the original ECU chip for optimum performance and
drivability.
<p>
<b><u>Features</u></b>
<br>
<li>Easy to use. Novice users can select preset performance settings.</li>
<li>4 Performance settings:
<ol>
<li>stock horse power + transmission shift firmness tuning</li>
<li>40 horse power + transmission shift firmness tuning</li>
<li>60 horse power + transmission shift firmness tuning</li>
<li>85 horse power + transmission shift firmness tuning</li>
</ol>
</li>
<li>Optionally raise the speed limiter</li>
<li>Full text OBD-II Diagnostics + diesel specific diagnostics</li>
<li>Real-time sensor input data monitoring (fuel, MAP, coolant temp, RPM, live diagnostic codes, etc.)</li>
<li>Clears DTC codes</li>
<li>300% larger screen than the competition</li>
<li>Backlit screen allows you to use the tool in full sunlight or total darkness</li>
<li>Can reprogram performance tune or restore stock tune <b>even if dealer reflashes the ECU</li>
<li>Port which will allow future download of updates and customized programs</li>
<li><b>30-day money back guarantee</b></li>
<li><b>Lifetime Warranty!</b></li>
<hr width=95%>
<p><b>Free Shipping With All Diablo Tuning Products!</b></font>
To order: http://motorhaven.autoanything.com/c...oduct=predator
<p align=justify>
<p align=justify>
drivability.
<p>
<br>
<ol>
</ol>
</li>
<hr width=95%>
Hehehe...oops
Too bad performance companies 'forgot' about the older trucks. Guess that they dont relize (or dont care) that there are still a lot of us out there ready to spend $. Most all the new stuff is for super dutys. I could have sent my $ to diablo, guess it's going to SuperChips now.
Thanks for correcting me.
Yea, that's what they said about the 'X'-moniter, still waiting for that too. I understand the consept behind it, it's just frustrating waiting. On the other hand, it helps to make sure the bugs are worked out before it gets to the other 'smaller market' groups.
I think the programers are bigger with the 99+ guys because their more worried about warrentys and all. If they take their truck in for warenty work, it's a lot easier to deprogram than it is to remove a chip. Almost all of the 94-97 trucks are out of warrenty already. If not due to milage, then to time.
Oh well, such is life. Thanks again for the info.
on
Originally posted by wgw
Ken, I am assuming this will be for any PSD January 99 on through? Can I do all of the programming and not take it to the dealer for any reflashing of the chip.
Thanks for any info
Thanks for any info
No need to take it to the dealer. You plug it in the OBD-II port, same way a Micro Tuner does. It reflashes the stock computer after saving a copy of the original program. You can restore the original program at a later date.
Thanks alot!
I've been on this site for days investigating chips. Just got home and set down to order the Diablo 54/78 and now I see the Damn Predator. Are the pre set (novice) modes other than being a few more HP set up with the same type power curve (that eveyones so happy with) as the 54/78 hp? Is the Pedator something that stays plugged in all the time? I dont understand all that hitech computer wizzard code stuff that it does. When I buy bigger tires, can I program it for that?
Bottom Line = Is it better than the Diablo 54/78 chip?
Pros?.... Cons?
Oh, by the way would I need my code to order?
Thanks
Pros?.... Cons?
Thanks
Sounds like you only need to know your code if you have a 99-99.5 truck. It doesnt stay pluged in all the time. You plug it in the diagnosis port, follow the instructions on the screen. Once it's programed ya unplug it and keep it in a safe spot so if you ever need to unprogram it (taking it to the dealer for work) you can do so easily.
It only took a couple mins to use my SuperChips Micro Tuner I got today, I'll assume that the Diablo is the same way.
on
Correct, the tuning procedure is similar to the Microtuner. However, you can optionally leave it plugged in as you drive and get live sensor data.
The presets use the same "signature" Diablo tuning. Other than HP, the results will be similar. You cannot change tire size calibrations with it. However, you can purchase custom tuning and the dealer can download it into the Predator.
Bottom line is, all the products are good --- each fills a different niche.
Ken:
I have not been able to find any info on the torque gains associated with the HP gains. Do you have any idea?
Also, I read where this tuner will be forever married to the truck it is programed to, so no reselling on ebay.
