Removing Fan Clutch
Do you mean wrench? I went out and measured the tool I bought for removing my fan from the motor and it measures 48 mm, but when I used it to remove the fan a few weeks ago when I did the oil cooler rebuild, I would have rather had a 47 as the tool felt a little loose but did the job.
Here is a linke to the tool...
Just did mine
The tool is 1 and 7/8ths inch open-ended wrench - there is no place for a socket in there as the fan clutch is on the end of the nut.
Useful tip - I found that Advance Autoparts have the fan clutch toolkit in their loaner tools section, cost me nothing to borrow, just put down a returnable deposit.
I just used it to re-install my fan stator (taken off during overhaul at my request) - big noise reduction in having it back on the truck.
PB
PB
FastMatt
06-20-2014 10:05 PM
steve340
05-10-2014 07:20 PM
cutlass
07-15-2012 11:16 AM
