96 f150 5.8 no spark, code p0320? - Ford Truck Enthusiasts Forums
Old 08-05-2010, 08:51 PM
ymountainman ymountainman is offline
ymountainman is starting off with a positive reputation.
Hey having trouble, my truck keeps dying. It will restart after 30min. No spark coming from coil wire. I have 12 volts at coil with key on. I got a motorcraft black ig module. sensor on crank, twice.Coil. I put cap, rotor, wires, and plugs. Getting a po320 code. Do you think it's the pip sensor in the distributor? It acts like a heat problem. thanks in advance!
Old 08-06-2010, 04:02 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Welcome to the site.
Change the stator assembly in the distributor. It has a bad PIP sensor in the stator assembly.
Turn the engine until it is at TDC and #1 is on its compression stroke. Pull the distributor out and tear it all the way down, replace the stator, put the distributor back in and time it at 10* BTDC with the SPOUT out. Then put the SPOUT back in and check to see if the timing has moved some, if so you are good to go.
You can also buy a new distributor but I would not trust a rebuilt distributor as most of them have bad PIP sensors in them also. You will just be taking back or replacing the stator in one of them.
Old 08-06-2010, 07:18 AM
thanks for the info. It may be to much for me to check out. Iv'e done my old truck dizzy. Im kind've skittish about this computer truck. I may cause myself more headaches. Thanks again!!
Old 08-06-2010, 07:34 AM
subford's Avatar
The distributor is about the same. Just bring number one up @ TDC on its compression stroke like you did the old one.
Unbolt the hold down bolt the same as the old one. Unplug it and pull it out.
Punch out the roll pin and pull off the gear at the bottom same as the point type.
Take the cap and rotor off of it and pull the shaft out the top. Unscrew the stator assy. and screw the new stator in.
It goes back to in the same as the old type did with the rotor pointing at #1 on the cap.
Do not turn the motor with the distributor out.
Hook up the timing light the same as the point type.
Here is something different, pull the SPOUT shorting bar out over on the drivers fender by the ICM.
Now start the engine and time it like the old type with the timing light to 10 * BTDC.
Tighten the bolt and recheck the timing. Push the SPOUT back in and recheck the timing, it should have moved. If it did you are good to go.
The SPOUT:
The Stator:
The Distributor:
Old 08-07-2010, 07:52 AM
Hey thanks!
That is what i needed to know. You can't get it any easier than that! I will try it. Thanks for the pics. I have a 76 f100 shortbed 4x4 i restored. It's got a roller cammed fe 4spd, 205. I put a 78 dana 60 under the front. 60 in the rear. I got a single wheel dana 70, and disc brakes off a 78 f350 2wheel drive and the brackets im gonna try and put the ford brakes on the rear if it will work. thanks again!!!
Old 08-08-2010, 12:06 PM
dumb question
Where is the timing pointer at? I was going to see where my timing was before i pulled the dizzy, just curious. Im not sure where it is? thanks again.
Old 08-08-2010, 02:22 PM
subford's Avatar
The Pointer:
The scale:
Old 08-08-2010, 07:11 PM
Im coming to Kansas to give you a hug!! Thanks again i'll keep you updated!
misfiring or bad cylinder Fast_trucker Ranger & B-Series 5 06-01-2015 02:32 PM
1979 F150 Very Small Spark From Coil jkesna 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-07-2013 03:30 PM
390 No Spark? Help Please!!! tjs_79ford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 09-20-2009 11:30 AM
1977 ford f250 getting no spark ymirr 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-17-2009 08:34 PM
97 f150 no spark, crank but won't start rednekrebel28 1997 - 2003 F150 4 07-30-2006 08:41 AM
Tags
150, 1996, 2001, 460, 96, code, econoline, escap, f150, f350, ford, losing, p0320, po320, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
