rear drums - 53 f100
I am struggling to get my rear drums off my truck. Its a 53 v8 f100 and should be pretty much stock. I made sure the e brake was loose and tried loosening the star adjuster from the back of the drum but it still does not want to come off. I pull with no luck like its still hanging.
Any ideas to try or am I missing a step? I looked in the manual and see front but no real reference to the rears.
Loosen the adjuster as much as you can, then tap the drum all around where the brake shoes make contact with the drum. Then as you tap with the hammer on one side of the brake drum put lite pressure pulling the drum with your hand on the other side. The idea is to keep the drum straght while its slowly coming off. Otherwise they will fight you the whole way. Go easy, good luck!
Just a thought, possibly you could drill the heads of the retaining pins that secure the brake shoes to the backing plates. In the process of drilling the pins the retaining springs may release if drilling causes the pin to spin. Don't drill into the backing plate. Just drill enough to weaken the head of the pin so it will break when you pry on the drum.
gary_b
10-16-2006 07:46 AM
pngasius4
06-15-2000 09:14 AM
