Holley 1904 glass bowls
#31
B2A9809A .. Glass Float Bowl Retainer Clamp (4 required-as original) / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 34 = 800-476-9653.
No Ford Dealer, no other obsolete parts vendor has any.
This clamp is not listed in DC's 1948/56 truck repro parts catalog.
DC ... besides selling repro parts, has a huge stock of NOS parts.
#32
Do you happen to a part number for the Retainer Ring?
#34
More bowls found...
Part 9559a at Tee-Bird Products Inc. - 1954 1955 1956 1957 Thunderbird Parts - 1954 1955 1956 Ford Car Parts / $13.50 ea / has "20 or so".
He does not have the retainer or clamps.
Jim
ps: Joblot is all out, has been for a while. Collectorsautosupply.com lists them, but they're out too.
Jim
#40
Maine52f1 - The float bowl from the single barrel carb used on MOPAR slant sixes is a direct swap (Holley #1920?). Some Internationals use the same carb (#1904) as the Ford sixes and they did not have the glass bowl from the factory.
Three warnings reguarding used / rebuilt 1904's:
- chipped and/or cracked bowls can be VERY hard to see, especially in low quality pictures (ie: most cell phones). If you're buying a 1904 just for the bowl and retainers look very carefully at the edge of the bowl or ask to see it with the bowl removed.
- the metal that carbs are made from is somewhat soft. Over time the screw mounting points for the bowl will "stretch". If the retainer clips are touching the face of the carb you could have sealing problems and might have to surface the face back to flat. In a pinch you can use two bowl gaskets, but this is a "band-aid" fix.
- the economizer valve poppet (under the three-eared cover on the top of the carb) can be stuck or even missing on used, or even rebuilt carbs. Looking in the bowl, the poppet is in the top of the arm that sticks out to the right on the main well. There should be a small brass piece sticking out the top of the arm. It should move up & down with gentle pressure. If it's missing the carb will flood constantly. If yours is missing or stuck you need another main well or need yours repaired. There is only ONE GUY who does this repair. He started doing this on International Scouts with the 1904. I'll post his contact info later.
Jim
Jim
#41
bhalemail
01-25-2017 09:43 PM
jvmcc
08-15-2016 05:16 PM
e william
35
02-03-2009 06:03 PM
