Cam Phaser replacement, to do or not - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-05-2010, 10:42 AM
F250_05SD F250_05SD is offline
F250_05SD is starting off with a positive reputation.
My truck like alot of others has cam phaser rattle on the passenger side. I see people in here that have fairly low milage having this proplem.
I want to know is it worth changing it at all, and if I do change it how long will it take to start rattling again?
Old 05-03-2011, 08:23 PM
MyFirstFordV10 MyFirstFordV10 is offline
MyFirstFordV10 is starting off with a positive reputation.
Just curious if you followed up on this clicking issue ? Mine just started what I'm guessing to be similar BS, and I'm trying to nail the issue down. Here's my thread:
http://www.ford-trucks.com/forums/10...06-v-10-a.html
Thanks,
B
Old 05-04-2011, 10:11 AM
I heard your engine noise on your video and thats not the cam phaser. The phaser on mine is the passenger side at the front of the engine, and the knocking noise is the opposite of yours, it is a light knock at idle and easy driving then increases in vol. as the engine works harder like pulling a hill.
I asked about the cam phaser replacement to try to find out how long the repair last.
I read posts that say they replaced the phaser and have it go out in 25k to 35k, my truck has 180k on it and I dont want to be replacing the phaser more than I replace the tires, lol.
I also read posts that say not to worry about the phaser noise.
wish you luck in fixing your engine.
Old 05-05-2011, 07:35 AM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
The early 4.6L 3V and 5.4L 3V engines had issues with the cam phaser and lash adjusters. My were replaced under warranty at 25K miles. I do not believe that they require frequent replacement if the parts are up to spec. Here is a TSB on the issue.
06-4-7***TICKING AND/OR KNOCKING NOISE FROM ENGINE - 4.6L/5.4L 3V
2005 5.4 starting, sounds like diesel Garden Spyder Modular V8 (4.6L, 5.4L) 9 01-23-2017 02:24 PM
Cam Phaser or Not? Kelly Crerar 2009 - 2014 F150 5 08-27-2016 07:22 PM
2005 Exp - what yr/model engines will swap? Mikec35 1997-2006 Expedition & Navigator 3 08-07-2016 10:43 AM
Help! Cam phaser, broken chain guide. dannyfumi 1997-2006 Expedition & Navigator 7 08-27-2012 07:15 PM
Cam Phasers and Spark Plugs 04XLTRUNNER 2009 - 2014 F150 9 11-17-2011 06:42 PM
Tags
2005, 54, cam, camshaft, diesel, duty, engine, f150, fazer, ford, heavy, phaser, phasers, replacement, specs, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
