Blower motor only running on high...? - Ford Truck Enthusiasts Forums
Old 08-04-2010, 09:04 PM
redbug's Avatar
redbug redbug is offline
redbug is starting off with a positive reputation.
Hello,
1985 6.9 Regular Cab long bed F250 4x4 with C6 trans, Cruise and Air.
Problem started with the second episode of smoke coming out of the ventilation system and filling the cab... First time I thought I had burned out the blower motor. Motor still worked.. Then I though I had burned out some wire under the dash.
This year the smoke came back and I finally found the problem..
Problem was that a mouse built a nest in my air conditioner right between the blower and the evaporator. What happened was the wire resistor for the blower motor that screws into the air conditioner area had set the mouse nest on fire.
Took the blower motor out and the resistor. Cleaned the cavity out and then reassembled the components. Ever since then the blower only goes on high and I'm freezing in the cab...
Any ideas what is wrong? Have I blown a fuse? Any idea which fuse? Or, have I burned out the resistor. I did take out the resistor and it looked fine...
Old 08-04-2010, 09:10 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
Most likely the resitor is shot. I have had it happen twice and the fan would only run on high.
Old 08-04-2010, 09:51 PM
powerstroker100 powerstroker100 is offline
powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.
whats the resistor? my truck does this same thing
Old 08-04-2010, 10:59 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
It's on the heater box in the engine bay has 3 or 4 wires and look like this http://www.ford-trucks.com/forums/pi...ictureid=37576.
Sorry for the poor cell image.
-Enjoy
fh : )_~
Old 08-04-2010, 11:22 PM
87crewdually's Avatar
87crewdually 87crewdually is online now
87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.
The plug with the 2 screws on either side is the resistor. Remove the plug then the screws and it will slide out. Usually under $30 at parts house.
Old 08-05-2010, 06:42 AM
redbug's Avatar
87crewdually and Festus, Thanks for the pictures. My 85 is a little different, 3 separate wires to the resistor, no plug, but its located in the same place. I think its shot, when I took it out last time after the smoke it was embedded with burnt wood chips.... Off to NAPA this afternoon.
I believe if you think your saving electrons by putting the fan on low your not, just sending some of the energy through the resister and putting off heat instead of turning the fan faster.
Old 08-05-2010, 08:54 AM
greywynd greywynd is offline
greywynd is starting off with a positive reputation.
redbug, there should be 4 wires, unless it's only a 2 speed switch in the cab. (Should be one for each speed, plus the... let's call it a return, as I don't think it is actually a ground.) A common issue on these is corrosion at that plug, I've had to dismember a couple of them and use spade terminals on each wire. Bit of a pain if you need to take it off later, but unless it's not working, something you rarely touch anyway.
Old 08-05-2010, 09:04 AM
redbug's Avatar
Ok, I could be off on the number of wires. Will check tonight, thanks.
Old 08-05-2010, 01:49 PM
Methanoholic
I believe, If you have factory A/C you'll have 4 wires, if you do not have factory A/C you'll have 3 wires.
Though don't go to the bank on that ...
-Enjoy
fh : )_~
Old 08-05-2010, 07:06 PM
kenpobuck's Avatar
My 88 had factory a/c and has 4 wires. The 81 doesn't have a/c and has 3 so you may be right festus.
Old 08-05-2010, 10:48 PM
awhtx awhtx is offline
awhtx is gaining momentum as a positive member of FTE.awhtx is gaining momentum as a positive member of FTE.
I had an '84 Ranger in the past and dry leaves got in that resistor and caught the truck on fire! It was a roaring blaze before I got it put out. The resistor is actually in the ground wire for the blower motor. Running the ground wire directly to ground gives High speed on the blower. Running it through the different resistors gives you the slower blower speeds. As you can see the resistors are made of different diameter wire to vary the resistance and thus the blower speed. Those resistors get red hot and that's why it's mounted so that the resistors are inside the blower air chamber.
Old 08-08-2010, 01:06 PM
redbug's Avatar
Wow, too bad about your ranger... Maybe I should put remove blower motor yearly to check for leaves on my maintanence list...
Ordered new resistor. Old one does have four wires. One lone connector and a three plug connector. My local NAPA did not have it and could not order it. Advance auto had it for $30.
Old 08-08-2010, 06:13 PM
You're lucky that yours only smoked and didn't catch fire.
The louvers in the cowl (between the base of the windshield and the rear edge of the hood) on the 84 Ranger were slots about 3" or 4" long and 3/8" wide. I now have a 01 Ranger and it has a bunch of 1/8" holes punched in the cowl. Don't tell me Ford was not aware of the problem of leaves falling through the slots and getting into the blower chamber and then into the resistor.
Old 08-08-2010, 07:37 PM
redbug's Avatar
I'm sure Ford was aware of it... My father was in manufacturing for over 40 years, he always says "There is no isolated incidence, if one fails, they all fail".
My house is surrounded by old growth forest, maybe its time for me to put a screen over the louvered vents...
Old 08-10-2010, 09:51 PM
redbug's Avatar
Picked up the resistor today, installed it, I now have 4 speeds on the fan... I'm not in an ice box anymore!
Blower Fan Intermittent Usaman 1999 - 2003 7.3L Power Stroke Diesel 3 11-10-2016 10:31 AM
MOUSE nest where fan blower motor r2000f150 1997 - 2003 F150 2 08-12-2015 01:41 PM
1983 E250 Club Wagon 6.9L Diesel Blower Motor issues! LeeTribeRide 1968-2013 Full Size Vans 3 11-09-2013 05:10 PM
Elect. Burning Odor A/C vent jippy Ranger & B-Series 5 03-21-2010 10:21 AM
Blower Motor Resistor Pack vjstangelo Excursion - King of SUVs 1 10-17-2008 08:34 AM
Tags
1999, blower, f150, f250, f350, fan, fast, ford, grouned, high, motor, run, running, runs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
