It may look pretty, but notice the allen head fitting toward the bottom? That's your WIF drain. And to change that filter down there means opening that WIF drain and letting all the fuel out or taking a diesel
There is an international (IH) plug you can buy (I'll dig up the part number) it's brass, has hand grip plus Allan head and has a stopper so it will not fall all the way out. On my set up I've a pre and post filter with 6.0 pump in middle, pre is a water separator too. Pre and post are all steel spin on filters, same size and thread size too iirc 30 microns and 2 microns. Have ran flawlessly not one problem. Pix in sig link under fluid mods.
