Temporary plywood tonneau cover
I'm going to need to make an empty 350 mile trip down to LA shortly.
I'm tempted to take a sheet of plywood and strap it down on some 2x4 legs to be level to the top of the box. Would it yield any practical mpg gains?
The box is wider than the 4x8 sheet, so there'd be 2 long open gaps down the length of the box. It is specifically a quick and dirty temporary 30min setup made of scrap wood that I have lying around. It'll remove since I'm hauling stuff in the back most of the time.
Any of you guys try this and see any benefit/difference?
thanks
thanks
thanks
thanks
thanks
thanks
Well, I finally tried this since I had nothing to lose as an experiment. I made a 700mile round trip out to Reno up and back on I-80 with a 6ftx4ft sheet 3/8" plywood that I've had sitting in the garage. I screwed it down on 2 pairs of legs made of some scrap 2x4's I was about to toss. I hacked the whole thing together in about 20minutes. I mounted it so the top was flush along the top of the box.
Anyways, compared to 4 near-identical previous trips around the same time of the year, this time I averaged about 0.8~1.5mpg better, hand-calculated, gas-station to gas-station on 3 fill-ups. The 0.8mpg was going there uphill, 1.5mpg was on the way back down. I drove 65-70mph most of the way.
Not a big deal, but if I'm averaging 14-15mpg, that works out to be 5~10% improvement, so of the $200 or
so fuel I spent on the trip, it works out to be about $15 savings. Not bad..that pays for my lunch.
For kicks, I'm going to try this again on the next trip just to see if I'm not imagining things.
Needless to say, wife was rather miffed and said it was ugly; I said it was just an experiment that could be disassembled in 2 minutes if needed. Now after seeing the mpgs, she's approved and is trying to convince me to get a real cover. :-)
So I'm wondering if any of y'all can or have tried this and see what you experienced... if you do it, make sure you strap it down real good....
aquaman - Just another thought, use luan. It's 1/4" mahogany and can look mighty fine IF you can pick thru the stack to get "the right piece". Some sheets have 'blems' and some looks good 'nuf for cabinet work. < strong + light weight. With a couple coats of urethane it sorta sparkles. OR with a bit of filler + sanding it can be painted to look like a fiberglas cover. I made one a while back for a friend, matched his truck with rally stripe. < custom + cheap. I have plans = for a short/narrow bed - can be modified to fit any. Pneumatic cylinders + 2 latches @ back + can have a spoiler if wanted.
IDID-J, Good work. I did similiar but lower profile and for looks as well as use. Boats are an 'interest' of mine - a thin layer of nylon + resin makes a boat/tub-like finish of done right. I used 1X4's and 5mm luan, slight arched top / rain runs off.Finished, it looked like an expensive custom cover but a LOT LESS $$. A friend of his wanted me to make a "cover" for his S-10 that would make his p/u into a fastback for racing. They both thought I was a bit 'tilted' when I told them to use a corvette roof.
I thought about putting in a painted plywood tonneau not for mileage but rather to keep the wet off my wooden bed. I thought about consulting my grandpa. He's the master of homemade stuff like that. On his Mazda pu, he made a hinged one that was painted, used bed corner anchors rigged with pins and padlocks to hold it down, and had rails along the sides of the long piece to eliminate flexing.
swampthang
06-29-2014 09:47 AM
nationm
1997-2006 Expedition & Navigator
15
06-20-2006 07:50 PM
