1942 Ford Fire Truck - Ford Truck Enthusiasts Forums
Old 08-04-2010, 10:22 AM
AaronBontrager's Avatar
AaronBontrager AaronBontrager is offline
AaronBontrager is starting off with a positive reputation.
I have two 1942 Ford Fire Trucks that I am working on. I am trying to identify them, and am having a a tough time. Here is what I have:
First Engine:
SN: 99T483893
Bell Housing: K6144 (I think I am missing a number, but it is too rusty to read)
Here are some other numbers found on the engine: 19 AP
Tag on Driver Side valve cover: 86
Second Engine
SN: 99T492434
Here are some other numbers found on the engine: 19-A AP KK TII
Bell Housing: K27133
Frame: 21T5087
Door Frame: T310-092N
I would like to know as much as I can about all these numbers
Thanks
Aaron
Old 08-04-2010, 09:36 PM
46fordtruck's Avatar
46fordtruck 46fordtruck is offline
46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.
The serial numbers are the ones that are most important. They tell you they are '42 heavy duty trucks. The rest or the numbers are just casting numbers, manufacturer stuff, most can't really be decoded or were known to the manufacturer. The 21T-5087 is a part number of that component of the frame. Ford never put door tags, so that tag was probably added at another time, maybe a fleet number or something, but not a Ford thing. Sounds like you have a couple of neat projects there.
Old 08-05-2010, 07:15 PM
Since I know know that they are 1942 engines, do you know if they are 90, 95, or 100 hp engines? or if they are Mercury engines?
Thanks
Aaron
Old 08-05-2010, 07:18 PM
Thank you for all the information that has been provided so far. It is great. I am new to the early v8s.
Thanks
Aaron
Old 08-07-2010, 09:24 PM
0ldV8truck's Avatar
0ldV8truck 0ldV8truck is offline
0ldV8truck is starting off with a positive reputation.
Are they the original fitment engine? the 42 truck was only 85 or 95 hp,21T and 29T,What is the number on back of block between heads? There is also a number on end of cam,under distributer,That is the cam grind eg 5T ,The 46,7 trucks went to 51T 59T series of motors 90 and 97 hp,I think the mercury engine was the 100 horsepower one,The war one had a relived block? they were a bit more torque but less hp,I beleive the releived block made them flow a bit better and ran a bit cooler,This is not gospel Its just info ive used myself over the years,All the best with your trucks,How bout some photos?
Old 12-06-2011, 11:45 PM
Figured it out
Both engines are 1942 Mercury 100HP engines. They are original, one engine had less than 8,000 miles on it. The trucks that they were in are 1942 Ford 2 -Tons.
Thanks for all the info
Trans Question ryanf77 1967 - 1972 F-100 & Larger F-Series Trucks 16 05-07-2015 10:51 AM
Need help from the Number Dummy saauvenshine 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 03-08-2015 01:23 PM
SN# confusion Willhunt 1947 and Older Ford Trucks 6 10-28-2014 08:23 PM
Criagslist Tranny Jumpdummy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-06-2012 09:50 AM
Struggling to Identify my truck mixon72 1947 and Older Ford Trucks 6 04-23-2011 10:58 PM
Tags
1942, 1947, 1950, antique, engine, fire, firetruck, ford, fourms, numbers, part, pictures, rusted, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
