cant for the life of me get my truck to start while its hooked up. i turn the key, i hear a click and the lights dim a bit, i try cranking but it just keeps cranking and doesnt fire up. i know people are gonna say clean the connections better but to be honest i think if they were cleaned any better i would get to bare copper
will double check next time i get around to the install, but pretty positive it was all plugged in correctly.....the fact that i was sent super duty instructions for the install makes me think they sent me a chip burned for a superduty 7.3.....any chance on that?
No the install is the same, just the location of the PCM is a bit different. Have you tried switching to a different tune to see if it will start? Did you have the keys in the ignition when you pulled the PCM?
chip was bought new, keys were def out when i pulled the pcm, and i do think i tried switching to a different tune to start it, but i might as well do it again and try that just to make sure. im guessing nobody had this problem when they did theirs?
