Just remove the access plate on the inside of the gate, It's 8 or10 torque head screws. Two nuts hold the handle, when done greese everything up, spray some ATF at the latch sites...good luck
Look inside the rear stake hole, you can get one half of her there, and the other would be through the access plate...they are kind of bullet proof, you may be able to loosen it up again
