How to replace a broken tailgate latch? - Ford Truck Enthusiasts Forums
Old 08-03-2010, 04:30 PM
Ford1988Trucker Ford1988Trucker is offline
Ford1988Trucker is starting off with a positive reputation.
My tailgate latch is broken and i need to know how to take it out and put the new one in. Any help is appreciated.
Old 08-03-2010, 04:37 PM
Slip ford man's Avatar
Slip ford man Slip ford man is offline
Slip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud of
Just remove the access plate on the inside of the gate, It's 8 or10 torque head screws. Two nuts hold the handle, when done greese everything up, spray some ATF at the latch sites...good luck
Old 08-03-2010, 04:56 PM
Its not the handle. It's the actual latch that holds the tailgate up.
Old 08-03-2010, 04:58 PM
Look inside the rear stake hole, you can get one half of her there, and the other would be through the access plate...they are kind of bullet proof, you may be able to loosen it up again
Old 08-03-2010, 05:31 PM
The handle latch is attached to the side latch that I am trying to remove.
Old 08-03-2010, 05:37 PM
Can't you disassemble? you gotta do what you gotta do
Old 08-03-2010, 05:41 PM
So once I unscrew the rod from the handle latch and pull it out, how do I get the side latch out of the component on the side?
Old 08-03-2010, 06:02 PM
Not sure, but I would guess that there are two nuts to remove
Tailgate Latch New To Ford 1957 - 1960 F100 & Larger F-Series Trucks 2 09-05-2016 02:33 PM
Only one tailgate latch works Ford'05HG Ranger & B-Series 4 11-18-2015 06:08 PM
Tailgate latch conchstew Explorer, Sport Trac, Mountaineer & Aviator 2 08-21-2012 02:25 PM
88 F150 tailgate latch broken. I need help! Ford1988Trucker 1987 - 1996 F150 & Larger F-Series Trucks 3 08-02-2010 09:25 PM
Ranger tailgate stuck StillAqua Ranger & B-Series 3 05-19-2010 02:24 PM
Tags
1972, 1979, 2000, 97, broken, explorer, f150, f250, ford, handle, latch, remove, replace, tailgate, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
