6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Turbo/boost failure 2008 F250
Old 08-03-2010, 09:02 AM
The Dark Knight's Avatar
The Dark Knight
The Dark Knight is offline
One of the turbo's was squealing at about 99k, the dealer said they replace the turbo, now I have the following intermittent problem. The turbo/boost fails and the truck has no acceleration. You can see the boost gauge is at zero and the accelerator is mashed to the floor, I could be cruising at 80 on the freeway and the back off for a second then try and pass a car and the boost dies, nothing. I pump the accelerator, put it neutral and rev the engine repeatedly until the boost comes back. This happens in a thousand different scenarios, to many to explain. The dealer had engineers look at the truck and they said there was an excess of carbon build up in the turbo's, I don’t know what they did but they cleaned it up and it went away for about 10k miles, now it’s back and much worse. The truck now has 129k miles on it and I’m at a loss, obviously it’s out of warranty. Any ideas anyone?
Old 08-03-2010, 09:23 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
sounds likethe electronics to the turbo's to me. Check the connection to the turbos and check your coolant level for it as well.
Old 08-03-2010, 10:28 AM
Tom's Avatar
Tom
Tom is offline
This could also be a fuel problem. Have your fuel filters been changed recently?
Old 08-03-2010, 11:01 AM
The Dark Knight
Yes I Have, we even make sure the water seperator is clean
Old 08-03-2010, 11:03 AM
The Dark Knight
It does in a way sound like something electronic, but nothing is repedative in the way it frees its self so its so hard to nail down
Old 08-03-2010, 11:19 AM
senix's Avatar
senix
senix is online now
I guess my best advice for now is the check all the connections, ensuring good contact. Check the mechanicals to the turbo for proper operation.
Old 08-03-2010, 02:07 PM
ChargersFanInCO's Avatar
ChargersFanInCO
ChargersFanInCO is offline
I'm not trying to make you sound stupid, but did you change the filter at the separator, or did you just drain it?
Old 08-03-2010, 02:39 PM
The Dark Knight
Yes, the filter at the seperator has been changed, not a stupid question at all. I cant believe no one else has had anything like this happens, this sucks. I could walk out to the truck right now, start it up and low and high turbo's won't boost, how is that possible?????
Old 08-03-2010, 03:08 PM
whitre's Avatar
whitre
whitre is offline
What about turbo clamps? Are they tight?
Old 08-03-2010, 03:10 PM
The Dark Knight
I will have our mechanic check those, recently there has been an exhaust smell in the truck while at a stop
Old 08-03-2010, 04:15 PM
senix's Avatar
senix
senix is online now
If you have an exhuast smell then there may also be other factors at play here.
Old 08-03-2010, 04:47 PM
kane gray's Avatar
kane gray
kane gray is offline
Maybe your EGR valve is stuck open. Although that would probably be too simple of a fix.
Old 01-16-2011, 05:09 PM
mspurr's Avatar
mspurr
mspurr is offline
loss boost and power
I have a 2008 F-350 with kind of the same problem, if I'm driving at about a 100 km and floor the truck to pass a car i have no power about a 1/4 of boost, then if you let off and ease in to the peddle the boost comes up but slowly. if you pull over and shut the truck off and start it back up the power is back and works find till u drive at a 100 or slower for 10 or 15 min. some times if you hold the peddle to the floor till it govern out the power will come back. i have had it in to ford a few time and they can't find anything wrong with it.
Tarheelldo
06-26-2016 07:22 AM
themaniam1
07-26-2014 11:07 PM
Km1210
01-05-2012 12:53 AM
turboboost
10-26-2009 07:20 PM
Hamberger
09-27-2005 01:27 PM
Quick Reply: Turbo/boost failure 2008 F250
