1993 7.3l IDI my first diesel
What size is the fuel line for the return hoses? I replaced my filter and knocked a couple of hoses off and noticed they are old and cracked to hell. I had some 1/4" fuel hose to patch it but it seems a bit too tight. Should i buy the kit from Pensacola? Are the o-rings that come with it not worth using and get those from McMaster Carr? What other parts should I replace while im in there?
Also, tight return line is good; as long as you can get the line on over the connector, you're fine.
O-ring wise, I don't know. It wouldn't surprise me at all if the ones in the kit *were* the same ones as the McMaster Carr ones... It's more that you will end up needing more than one set's worth, if you tweak your system at all.
The O-rings don't seem to do as well these days, what with the ULSD and all, though that may be all a matter of just disturbing them.
Also, a little tip: Use Lithium grease(I'm using wheel-bearing grease) to install your O-rings, not Petroleum Jelly as I've seen suggested. It seems to do very well, and the ones I've installed this way don't 'weep' for the first couple of heat/cool cycles, like they used to.
Also, this lithium grease will not melt at top-of-engine temps; so any that's on the outside of the O-rings will /stay/ there... not that it will make any real difference, I don't think.
Cool! More good info for the never-read FAQ.
Injector Installation Kit
Many prefer to toss the o-rings in the kit (and I highly suggest you do) and use these Viton Return O-Rings - McMaster-Carr Item 9464K24, Viton is impervious to Diesel.
For the Injector Installation Kit installation You can follow Starmilts Humorous Fuel Return Replacement Procedure, I like to cut the 6 pieces between the Injectors to 4-1/16", Use a sharp razor blade to cut the hose and Vaseline to lubricate the o-rings.
For proper fuel system bleeding you can use steps 1 through 4 and 13 through 15 of the Fuel Filter Replacement.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
Romel1088
04-03-2019 12:09 PM
Blakester122
09-01-2015 10:51 AM
fedx95
Ford Truck Parts for Sale
02-17-2015 07:08 PM
