1993 7.3l IDI my first diesel - Page 2 - Ford Truck Enthusiasts Forums
Old 06-14-2014, 04:33 PM
Mechdziner714's Avatar
Mechdziner714 Mechdziner714 is offline
Mechdziner714 is starting off with a positive reputation.
What size is the fuel line for the return hoses? I replaced my filter and knocked a couple of hoses off and noticed they are old and cracked to hell. I had some 1/4" fuel hose to patch it but it seems a bit too tight. Should i buy the kit from Pensacola? Are the o-rings that come with it not worth using and get those from McMaster Carr? What other parts should I replace while im in there?
Old 06-14-2014, 05:49 PM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by hairyboxnoogle View Post
Boy this thread sure throws into contrast the guys that arent around anymore.
Huh, how do you mean?
Quote:
There are two return line systems out there; the older style had a single barb on each connection, and used 3/16" line. The newer system has multiple barbs on each connection, and uses 1/4" line(the tubes are bigger, too).
Also, tight return line is good; as long as you can get the line on over the connector, you're fine.
O-ring wise, I don't know. It wouldn't surprise me at all if the ones in the kit *were* the same ones as the McMaster Carr ones... It's more that you will end up needing more than one set's worth, if you tweak your system at all.
The O-rings don't seem to do as well these days, what with the ULSD and all, though that may be all a matter of just disturbing them.
Also, a little tip: Use Lithium grease(I'm using wheel-bearing grease) to install your O-rings, not Petroleum Jelly as I've seen suggested. It seems to do very well, and the ones I've installed this way don't 'weep' for the first couple of heat/cool cycles, like they used to.
Also, this lithium grease will not melt at top-of-engine temps; so any that's on the outside of the O-rings will /stay/ there... not that it will make any real difference, I don't think.
Old 06-15-2014, 07:54 PM
Chevy_Eater's Avatar
Chevy_Eater Chevy_Eater is offline
Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.
Cool! More good info for the never-read FAQ.
Quote:
Originally Posted by Festus Hagen View Post
Injector Installation Kit
Many prefer to toss the o-rings in the kit (and I highly suggest you do) and use these Viton Return O-Rings - McMaster-Carr Item 9464K24, Viton is impervious to Diesel.
For the Injector Installation Kit installation You can follow Starmilts Humorous Fuel Return Replacement Procedure, I like to cut the 6 pieces between the Injectors to 4-1/16", Use a sharp razor blade to cut the hose and Vaseline to lubricate the o-rings.
For proper fuel system bleeding you can use steps 1 through 4 and 13 through 15 of the Fuel Filter Replacement.
-Enjoy
fh : )_~
1993 7.3L IDI losing prime Romel1088 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 03-29-2016 08:38 PM
1993 7.3L IDI Piston Numbers Blakester122 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-01-2015 10:51 AM
1993 Ford 7.3 IDI Injection Pump Factory Turbo fedx95 Ford Truck Parts for Sale 1 02-17-2015 07:08 PM
WTB- 1993-94 7.3L idi turbo diesel Feardeere7 WTB - Parts & other 1 08-24-2014 02:49 PM
Looking for 1993-1994 7.3l idi diesel Feardeere7 Michigan Chapter 4 05-27-2014 05:37 PM
Tags
1993, 73, 73l, bleeding, deisal, diesel, filter, fuel, idi, international, leaking, specs, starting, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
