Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-02-2010, 02:13 PM
nathan69-360's Avatar
nathan69-360 nathan69-360 is offline
Garage is empty, add now
nathan69-360 is starting off with a positive reputation.
69, 87-96 drivetrain and frontend swap
i'm thinking i want to swap my drivetrain with one from an 87-96 f150, does any one have any insight as to what problems i might run into.
  #2 (permalink)
Old 08-02-2010, 02:18 PM
I guess i should have told ya'll its a 69 long bed F100
  #3 (permalink)
Old 08-02-2010, 04:58 PM
Cekkent Cekkent is offline
Cekkent is starting off with a positive reputation.
If your 69 has a 6-cylinder and your f150 has a V8, you'll need to figure out how to mount the engine.
  #4 (permalink)
Old 08-02-2010, 09:45 PM
No it has a 360, what i'm really wondering about are potential computer problems, since i'm planning on using an EFI 302 or 351w drivetrain, also i'm wondering about potential problems if I wanted to change out the entire front end, as mine does not have power steering.
  #5 (permalink)
Old 08-02-2010, 09:53 PM
I love my truck, I love the look of it, this has always been my favorite body style (well maybe not the longbed), but I would like to make it a little more every day driver friendly.
  #6 (permalink)
Old 08-03-2010, 12:12 AM
RichS2659 RichS2659 is offline
RichS2659 is starting off with a positive reputation.
Are they both 2WD? If they are, I think the 80-96 I-beams will be slightly longer, so they can't bolt right in. If you want disc brakes, get a kit. You can redo your older I-beams with new bushings, and also change the kingpins if they are getting sloppy.
  #7 (permalink)
Old 08-03-2010, 12:55 AM
danger-ranger93's Avatar
danger-ranger93 danger-ranger93 is offline
danger-ranger93 is starting off with a positive reputation.
i have a 87 and i have looked at the 73-79 f150's and compared it to mine and there are some big differences. the 73-79 dosent have caster camber bushing and spindels which makes it stronger than mine, yet also harder to have alighned if your caster camber gets out of wack.
the 87-96 beams are longer, i think, i didnt put a tapemeasure on them to see for sure.
if you did do this you might as well buy a whole parts truck and pull all the parts you will need.
as for the motor swap...i would try and find the closest to 96 as you can because not only did they swap to MAF they also put roller cams in them then and they made more power stock. my 87 has MAP which has hardly any adjustability as far as adjusting that stock power settings and makes it harder to add preformance upgrades.
now that im thinking about it, the fox body mustangs had all that stuff throughout their production so unless you just absolutely want a TRUCK motor i'd see if you could find a mustang motor/wiring harness and all. and as for it being a truck specific motor you could get a roller cam and put in. just depends on what you want and can afford really.
__________________
Michael, but you can call me Michael, or danger ranger what ever you preffer
'87 f150 4x2 reg cab short box, 302, M5OD-R2, custom cab sold.
'96 f150 4x2 extended cab, 302, M5OD-R2. XL FOR SALE
'78 F250 4x4 reg cab long box. Project
'00 F150 4x4 supercab, 5.4, auto XLT, DD
  #8 (permalink)
Old 08-03-2010, 08:03 AM
Thanks guys, that was kind of what I was wondering about on the front end, as far as the drivetrain was concerned, I kinda figured it shouldn't be too difficult to find a later model with EFI, and yea I kinda figured on finding one that was beat to crap and just stripping it. Come to think of it though the old 5.0 T-birds are going real cheap, might be a better option than an old fox body.
  #9 (permalink)
Old 08-03-2010, 01:37 PM
OK so i went through carcrafters thread on swapping the front end out with one from a crown vic, awesome idea, I hadn't thought of that at all. and our local police force has just recently gone to the chargers so there should be plenty available, and depending on the mileage I might even swap out the drivetrain as well. now just to get my hands on one, I'm not looking forward to dropping it at all considering it's a long bed, i just don't feel it would look right, and I think I'll leave the rear end as is, I suppose I'll have to add some boxing on the under side of the frame.
  #10 (permalink)
Old 08-07-2010, 12:50 AM
69powerstroker 69powerstroker is offline
69powerstroker is starting off with a positive reputation.
just so you know, you will need to use 89-93 mustang parts if you want MAF, the earlier ones used MAP as well. if you need info on this let me know and i can supply info and links to part numbers.
  #11 (permalink)
Old 08-07-2010, 01:21 AM
thanks..i would be interested in finding out what all i need to swap to MAF if you could pm me all the info so we dont clog up the thread
__________________
  #12 (permalink)
Old 08-08-2010, 10:26 AM
I've bought a 93 T-bird for $1050 with a 393 stroker built from a 351W, with a Vortech ysi supercharger, trans was built for it as well, rear end is no good, wraapped the backend on a tree. trans case is intact so we'll see. I haven't gotten into it yet just got it home about 2 in the morning.
  #13 (permalink)
Old 08-18-2010, 09:40 AM
TXstroker01's Avatar
TXstroker01 TXstroker01 is offline
TXstroker01 is starting off with a positive reputation.
Awesome find! Let me know if you're interesting in selling the Vortech. I may be interested.
What happened to the fresh 390/AOD you got from your family friend? Did that motor/trans not work out for you?
__________________
Brent
2003 Expedition 4x4 5.4L w/supercharger
2001 F250 SCLB PSD 4x4 (for sale)
1969 F100 Ranger
  #14 (permalink)
Old 08-19-2010, 06:12 PM
UGHH! he had some other buddy of his offer him more money before I was able to get over there and he went ahead and sold it. He's kinda that type though.
  #15 (permalink)
Old 08-19-2010, 06:26 PM
OOHHH! no that motor is still in, and working great, this is for a second truck, At first i was gonna buy it for parts, then decided to build it and maybe sell it. I was trying to deal with him on another block, and trans, that he sold out from underneath me.
Tags
4x4, 69, 79, 8796, drivtraine, end, f150, f350, ford, front, frontend, parts, sale, supercharger, swap, truck, vortech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
