Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-02-2010, 12:59 PM
00excursion 00excursion is offline
Garage is empty, add now
00excursion is starting off with a positive reputation.
brake caliper bolt size
Before I tear into my brakes and realize I don't have the right tool, does anyone happen to know what is needed to loosen the caliper bolts on 07 expedition? I've gotten conflicting details as to hex or torx and size, any details would be appreciated.
  #2 (permalink)
Old 08-03-2010, 08:51 PM
07shelby's Avatar
07shelby 07shelby is offline
07shelby is starting off with a positive reputation.
Just literally got back inside tonight after doing my 08 Expedition brakes.
The caliper pin bolts are an allen(hex) head that is 9mm. Its not a torx
Most hardware stores may not have a 9mm on the shelf, usually the sets
have an 8mm and then a 10mm...but no 9mm.
There out there..snap on and such...just get it before you jack her up to do the job
  #3 (permalink)
Old 08-04-2010, 04:44 PM
Thanks for the details, greatly appreciate it!
  #4 (permalink)
Old 08-05-2010, 02:37 PM
07shelby's Avatar
Glad to help. Doing the rear brakes tonight.
  #5 (permalink)
Old 08-10-2010, 06:35 PM
dturnersr's Avatar
dturnersr dturnersr is offline
1995 Ford F-250
dturnersr is starting off with a positive reputation.
9MM
Yup, I found out the hard way. Got it all up in the air wheels off, tried both metric and standard size...did not have a 9MM. I ground off an extra 3/8 allen to fit...then went and bought the right one
  #6 (permalink)
Old 07-15-2012, 12:40 PM
Jaylegger Jaylegger is offline
Jaylegger is starting off with a positive reputation.
Old thread but the info provided though correct is incomplete. As stated the bolt are hex, 9mm hex for front brakes and 7mm for the rears. A torx (dont't recall which size) will fit and grab enough to remove the rear, unsure about the fronts. Valid for 07 navigator anyway.
  #7 (permalink)
Old 09-02-2012, 11:38 AM
raynaldthomas raynaldthomas is offline
raynaldthomas is starting off with a positive reputation.
I've tried a 9mm and it was too small. I have a 2008 expedition limited is there any difference between the limited and the other models?
Tags
1999, 2000, 2007, bolt, bolts, brake, caliper, expedition, f150, ford, lincoln, navigator, posts, size, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
