Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > North Carolina Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
  #1 (permalink)
Old 08-02-2010, 11:00 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.
Don't take your truck to...
Cella Ford in New Bern. Especially if you have a diesel.
My '95 F350 Powerstroke 7.3 was in their shop for a whole month and still isn't fixed. They didn't diagnose it correctly, replaced a part that didn't fix my problem, and I got charged over $1,000 for parts and labor.
Their diesel mechanic is hardly ever there, they don't call you back with updates, and they don't seem to know much about diesels. At least not 7.3's.
I had it towed to a different diesel shop in town now.
__________________
Brownie (Evan) Ooh-Rah! Once a Marine Always a Marine Oregon Chapter Member
'95 F350 CC 4x4 - 7.3 PSD, 190k, Built E4OD, SRW Conv, 4x4 Conv, Rosewood Stage I's, PHP Chip, 6637 Intake, 3" DP, Lost Kitty, 4" Exhaust, 3" RSK, 38 gal rear tank, fuel vent mod, 140v IDM, HPX, FPR Shim, 3.55 gears
'10 Escape, 200hp 3.0 V6, 4x4 - Stock
  #2 (permalink)
Old 08-02-2010, 12:05 PM
MAKO314's Avatar
MAKO314 MAKO314 is offline
Garage is empty, add now
MAKO314 has a good reputation on FTE.MAKO314 has a good reputation on FTE.
What's your truck doing, or not doing man? what did they replace?
__________________
Ashley
2000 F250 Destroked "Frankinstien" CR 5.9 Cummins 631 HP 1389 lbtq
2003 explorer limited AWD V8
1990 7-UP mustang 5.0
  #3 (permalink)
Old 08-02-2010, 02:00 PM
1995 Ford F-350
The HPOP was not getting oil, so the first thing they did was replace the LPOP without checking the IPR or the oil bypass valve.
They also said originally that they were getting oil pressure but it was low, then after replacing the LPOP they had no oil pressure, then they tried to tell me that they never had oil pressure to begin with, even though the invoice says that they had pressure. The service manager said "Oh, I must have typed that in wrong".
Plus they wanted to fill up my engine with kerosene to "unplug it".
__________________
  #4 (permalink)
Old 08-03-2010, 10:49 AM
MAKO314's Avatar
Yeah it sounds like you need a new tech, it about has to be the by-pass or the lpop. if the engine were all plugged up you would still have some pressure. about the whole kerosene thing it works great on most engines but I don't think I would try it on a HEUI injected diesel. sorry you're having so much trouble.
__________________
Ashley
  #5 (permalink)
Old 08-03-2010, 11:16 AM
1995 Ford F-350
I took it to a different shop and they are looking into it. They are checking the bypass right now (I told Cella to do it but they wouldn't even try).
The new shop is suspecting a damaged front cover, which should be able to be visually verified when the LPOP is removed, so Cella should have caught that when they removed the old LPOP.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
