No check engine light but sputters - Ford Truck Enthusiasts Forums
Old 08-02-2010, 01:23 AM
YZ250rider YZ250rider is offline
YZ250rider is starting off with a positive reputation.
Back in Feb. went through a bunch of really deep snow and my truck started to sputter really bad. Well since then it has gotten better but still does it about evey other time I drive it. No check engine light so not sure what it is, but i think it is something that is low on the truck because it started when I went through the snow. When it first started to do it I popped the hood and the c.o.p wasnt wet at all so im thinking it had to be lower on the truck some were. 99 v10 118xxx 4x4 Thanks for any replies.
Old 08-02-2010, 12:32 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
That low, could be the crank position sensor, but do the easier thing first - check for a dirty MAF. When does it do it? Acceleration? Idle? what?
Old 08-02-2010, 02:24 PM
Accleration but it isnt everytime I drive it .Maybe like 80% of the time and sometimes its really bad. Almost seams like theres a loose wire or something.
Old 08-02-2010, 02:29 PM
Krewat's Avatar
Sounds like a misfire, caused by a wet spark plug hole.
Best thing would be to pull the COPs and see if you find any gunky/moist boots.
When were the plugs last done?
Old 08-02-2010, 02:36 PM
3 years ago and they are motorcraft and about 21000 miles ago
Old 08-03-2010, 05:07 PM
Mr-Pipeline's Avatar
Mr-Pipeline Mr-Pipeline is offline
Mr-Pipeline has a good reputation on FTE.Mr-Pipeline has a good reputation on FTE.
Have you checked the air filter? Might have gotten snow in the air filter causing damage and reducing air flow. Also, could have gotten onto the MAF. Just going for the easy stuff first.
Old 08-05-2010, 05:59 PM
greenego greenego is offline
greenego is gaining momentum as a positive member of FTE.
Have it scanned for codes. You could have a pending code showing a cylinder misfire without a check engine light being on.
Old 08-15-2010, 10:39 PM
PPrash PPrash is offline
PPrash is starting off with a positive reputation.
I picked up a 99 V10 4 weeks ago. It had a sputter/ missfire. Ended up I could hear a tapping when I first started it and got out of truck, then it went away, then I heard it again. Quick opened the hood and got a milk crate to stand on to get in close. As I got closer I knew it was not a typical mechanical lifter tap but a electrical arch snap. I then found a coil bolt loose and shut it off. took the bolt out and pulled the coil. Low and behold the boot was split up the length part way and was misfiring out sideways through the crack. I replaced the boot and it immeadiately ran smoother at idle and the occasional stumble on highway is gone 100%. Well, that is my story anyhow.
5.4 v8 Xcursion no power to move the truck. 809taino Modular V8 (4.6L, 5.4L) 7 02-03-2013 10:15 PM
Sputters When Put Into Park Rynil2000 Explorer, Sport Trac, Mountaineer & Aviator 4 12-19-2012 10:01 AM
When in gear engine sputters virgojeep 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-11-2009 07:27 PM
Sputtering under load Drgslayr Ranger & B-Series 11 07-16-2009 03:49 PM
HARD Start in Cold Morning EFI 460 TheMonkey 1987 - 1996 F150 & Larger F-Series Trucks 11 02-04-2009 07:04 AM
Tags
97, aviator, bad, check, connect, cougar, drove, engine, f150, ford, light, real, snow, sputtering, sputters, transit, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
