1974 F350 for parts
1974 F350 for parts
Category: Accessories
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude
Item Condition: CT
Engine: Part suitable for gas truck
This was an F350 dualie with a welding body.
Pretty much everything has been pulled off. The welding bed was sanded and POR-15'd. Same with the frame. The motor was pulled (it DID run, I have no idea why that was a "good idea" but there ya go). It's a 390 with a granny 4 spd, 104K.
There are 1.5 cabs. The original cab needed a lot of work on the cab mounts. This was completed but is by no means stock. I have the top half of a cab, as the original has some rust above the passenger door.
Here are some pix of when we first started to work on it: 1974 Ford F350
The only thing I am not sure of still having would be a seat. There were two and I know at least one of them sat outside and got tossed. There is one, if not two driveshafts, a couple of spare doors and I'm sure a host of other parts. There may be spare fenders too.
All reasonable offers considered.
Pricing on some items: Engine - $500
Tranny - $200
Both - $600 (you pull them apart)
Full cab - $300
Cab roof - $100
I have the dually rear end from the truck and a non-dually rear end from another van.
Gas tank (went in cab behind seat)
I believe I have a black reproduction carpet stored in the attic, never installed - $200
Steering column and steering wheel (they are still attached so take both)
Grill
I also have reproduction cab mounts
Local pickup only and you must bring enough people to help you move it. I will do what I can but you can't count on me to be the only helper - it's big and heavy - and I'm not.
Cash only, exact change only.
I can take other pix as well since a lot of stuff has been moved since the pix shown were taken.
Thanks for looking!
ps guess I can't upload photos anymore? Email me and I'll send them
Located vacuum control switch/AC & heat 1974 F100
Need vacuum air and heat in-dash control switch for 1974 F100. Sits behind the temperature control panel on the dash, has several vacuum ports and an electrical on-off switch built into the unit.
Part located through eBay. Gentleman from Lacey Springs, Alabama was kind enough to offer it.
