long bed vs. short bed? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
View Poll Results: Would you order a long bed or a short bed?
long bed 47 51.09%
short bed 28 30.43%
long bed with factory fifth wheel / gooseneck prep 17 18.48%
Voters: 92. You may not vote on this poll
Old 08-01-2010, 05:31 PM
commtrd commtrd is offline
commtrd is starting off with a positive reputation.
I finally got a 2011 SD on order and ordered the short bed. I am torn between just keeping the truck order as is or changing to the long bed with the factory fifth wheel / gooseneck option. Can't get the factory fiver / gooseneck prep option with the short bed. So if I keep the short bed is it not recommended to install for the fifth wheel stuff on a shortbed? Is the resale value better with a longbed or doesn't really affect it? I understand that towing with the long bed is supposed to be safer and especially if towing a fiver or gooseneck? It is not too late to change the order if I decide to but wanted to get some pointers on this from you guys.
Old 08-01-2010, 05:42 PM
Mr.RonGilbert's Avatar
Mr.RonGilbert Mr.RonGilbert is offline
Mr.RonGilbert is starting off with a positive reputation.
If there is any doubt I would go with the long bed. I am not a huge fan of the factory fiver/goose option. I like the flip option better but that's me.
I often wish I had the longer bed when I had my short bed and when I bought my 2010 the long bed was the way to go. I am very happy with the decision, I carried a bed and trailer full of stuff for the deer camp and there was no room to spare. When I add the 100g fuel tank I will need the extra bed space for sure.
Old 08-01-2010, 05:46 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Quote:
Originally Posted by commtrd View Post
So if I keep the short bed is it not recommended to install for the fifth wheel stuff on a shortbed? I understand that towing with the long bed is supposed to be safer and especially if towing a fiver or gooseneck?
You'll be fine with a short bed, you just need to install a sliding 5th wheel hitch. Lot's of guys on here run that exact setup, without any problems. People recommend long beds because the extra 15 inches at the front of the bed allows you to turn past 90* when backing up the trailer. With a sliding hitch, you can do that with a short bed, you just have to slide it.
Towing a gooseneck isn't a big deal with either bed, since usually stock and horse trailers have tapered nose, so contacting the cab isn't an issue. If it does have a square nose, you can get a 4" offset ball for the gooseneck to set the hitch back some.
I personally prefer a short bed/short wheelbase truck, mainly because the turning radius is smaller, so on smaller trailers like I tend to carry it's a lot easier to control the trailer. When you start talking about a really long trailers (30+ feet), truck length goes out the window, almost anyone can put it where they want to, because the trailer is significantly longer than the truck.
I haven't seen this "factory hitch setup" in person, so I can't speak to it's usefulness, but B&W has been making flip-over gooseneck ***** and companion hitches a lot longer than Ford has been installing them in the factory, so I'd personally stick with what I know and install one after you get the truck.
Old 08-01-2010, 06:01 PM
KC8QVO's Avatar
KC8QVO KC8QVO is offline
KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.
I voted long bed. If you are buying the truck as a tow rig and that is what it is going to be used for the majority of the time then you will want the long bed. The longer wheel base will handle better with a bed mounted hitch - 5th wheel or gooseneck.
That said, you can pull most of the same trailers with a short bed. If you get a slider for a 5th wheel camper, for example, the manuverability isn't a problem - on the road. Just slide the hitch back if you're going to do any fancy manuvering.
If this truck is your daily driver then maybe just keep the short bed that you ordered - unless you need or want the extra space of the full 8' bed.
I would personally prefer a short bed truck right now, but thats just me. I don't need a long bed and right now as I don't have a use for a bed mounted hitch. If I had a goose neck or a 5th wheel trailer I would think long and hard of getting a long bed. At that point I would get a dually too = very stable towing platform. Again, just my opinion.
Old 08-01-2010, 06:12 PM
spinella's Avatar
spinella spinella is offline
spinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to behold
i'd buy a 10' bed if it was available.
Old 08-01-2010, 06:37 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
Long bed is the only way to go. You actually have room in the bed to haul things or in your case to PROPERLY tow using a fifth wheel or gooseneck. After the tool box you still have room. Not to mention the long bed actually looks like a truck instead of looking like cat that got kicked in the ***.
Old 08-01-2010, 07:05 PM
Rugby3's Avatar
Rugby3 Rugby3 is offline
Rugby3 is starting off with a positive reputation.
Long bed all the way.
Old 08-01-2010, 07:11 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
Quote:
I have 10' long flatbed and wish I had 16
Old 08-01-2010, 07:13 PM
skip mitchell skip mitchell is offline
skip mitchell is starting off with a positive reputation.
I had an 05 F250 short bed CC cab now have an F350 SRW CC long bed I like the long bed as stated I would have a 10 Ft bed if offered,I buy a truck to haul and want all the space I can get,if you don't need the hauling space,short is ok but I want more.
Old 08-01-2010, 07:20 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Longbed is always the way to go unless you're in the middle of a U-Turn. They tend to ride smoother too.
Old 08-01-2010, 08:30 PM
Thanx for the replies. I am seriously leaning towards amending the order for the long bed.
Old 08-01-2010, 09:06 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
I threw my vote in for a long bed, but then again, I don't drive pickups with more than 2 doors.
Old 08-01-2010, 10:16 PM
Sand_Man's Avatar
Sand_Man Sand_Man is offline
Sand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud of
Since my truck is also my family ride, I had to go with a crew cab, and because of that I had to go with a short bed since I didn't want a truck that's a block long. Mine is bad enough in tight spots.
Old 08-01-2010, 10:22 PM
FoxNotch FoxNotch is offline
FoxNotch is starting off with a positive reputation.
+1.
I can't comment on 5th wheel setups, but I couldn't own a shortbed truck.
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.
Same here, and it would be behind a crew cab. You get used to the length.
Towing in Fifth sgrol 6.7L Power Stroke Diesel 19 01-09-2015 11:38 PM
Gooseneck recommendations for F250 SB Mark_in_co Fifth Wheel & Gooseneck RV Towing 9 04-20-2014 06:12 AM
what determines the weight rating in fith wheel hitches kevind95 Fifth Wheel & Gooseneck RV Towing 16 08-13-2012 03:29 PM
New 2012 6.75 bed??? dixoncity 6.7L Power Stroke Diesel 15 07-12-2011 07:09 PM
Gooseneck Trailer with short bed super cab??? vlietracer64 Fifth Wheel & Gooseneck RV Towing 9 01-28-2008 05:51 PM
Tags
2008, 5th, 8, bed, extra, f350, ford, gooseneck, long, ranger, rig, short, tow, truck, trucks, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
