Heater/AC control panel NOT turn-on occasionally - Ford Truck Enthusiasts Forums
Old 08-01-2010, 03:02 PM
Andy91st's Avatar
Andy91st Andy91st is offline
Andy91st is starting off with a positive reputation.
The heater/AC control panel does not turn-on automatically after the engine is started occasionally, during this time none of the buttons are working and blank display. The only way I can get it turn back on is re-starting the engine, sometime it takes more than 1 re-start.
I thought the relay ? or the signal driving the relay has something to do with it. Where is the relay for the Heater/AL is located ?
I am wondering what your thought is or how to resolve this issue ?
Thanks
Old 08-01-2010, 03:42 PM
Excurvelle's Avatar
Excurvelle Excurvelle is online now
Excurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud ofExcurvelle has much to be proud of
It is the control head going bad. Some people have said to turn the lights on and off 3 times and that will reset the unit when it acts up. I had the dealer replace mine under the ESP I purchased.
Old 08-01-2010, 04:45 PM
jeepman_79's Avatar
jeepman_79 jeepman_79 is offline
jeepman_79 is starting off with a positive reputation.
Headlights on off
This works when mine does this its happened 3 -4 times in the last 2 yrs. The First time we were on a trip it was hot I put the windows down when it got dark the lights came on so did the AC. So each time its happened I turn the light switch and then the panel works again ,and I thought I was the only one with this weird problem. Thanks for telling me whats wrong
Old 08-02-2010, 02:14 AM
Andy91st's Avatar
Since the problem only happens occasionally; 1-2 time a month and it is not possible to re-create. How do you think Ford ESP will handle this intermittent problem ?. My ESP good till Sept 2011.
Thanks
Old 08-02-2010, 10:51 AM
jeepman_79's Avatar
problem
I don't have ESP my truck is sold as of sometime this week can't decide whether or not to tell the new owner of a problem that may or may not happen. But I probably should
Old 08-02-2010, 01:41 PM
Excurvelle's Avatar
Quote:
Thanks
My dealer and I have a good relationship, I actually worked there as a service manager years ago. All I did was describe what happened and they replaced the control head under the ESP, I think it is a common problem.
Old 08-13-2010, 08:38 PM
wprebeck wprebeck is offline
wprebeck is starting off with a positive reputation.
Well, mine is doing the same thing. Just to clarify, the control head is the actual panel with all the buttons and LED on it, right?
It doesn't seem to be all that hard to replace, and they're readily available online; just wanted to be sure I'm replacing the correct part first.
Thanks.
Old 08-14-2010, 12:38 AM
Andy91st's Avatar
Yes, it also has the display showing the temp. air/heat flow position etc..
I will take it to the local Ford on Monday to check it out under ESP.
Thank you all for your suggestion/inputs.
Old 08-14-2010, 10:58 AM
kev03 kev03 is offline
kev03 is starting off with a positive reputation.
Mine does this, and there is other threads talking about this being tied into the automatic head light switch. If you turn off this switch and restart the truck they will come back on!
Old 08-14-2010, 11:05 AM
jeepman_79's Avatar
Headlight switch
On mine if you turned the headlight switch on and off even while driving the AC would start working and the panel light up
Old 08-14-2010, 11:24 AM
I have not tried this. As when mine does not work I have been stopped at different places and I also read if you turnoff the head light instead of using the auto feature this does not happen. this does affect my windows and radio too. It does not cause this problem when using the regular light feature.
Old 08-14-2010, 12:26 PM
jeepman_79's Avatar
Interesting
I had a problem with my sunroof several weeks ago I kept thinking there was a general electrical issue's going on beside the AC/Heat panel
Old 08-14-2010, 02:15 PM
2003 EXCURSION 2003 EXCURSION is offline
2003 EXCURSION is gaining momentum as a positive member of FTE.2003 EXCURSION is gaining momentum as a positive member of FTE.
This problem is now appearing on here about once or twice a week for whatever reason. Here is a recent thread with another pretty good discussion of it, I hope it helps. Mike
http://www.ford-trucks.com/forums/63...n-an-03-a.html
Old 12-03-2010, 05:51 PM
doug.c doug.c is offline
doug.c is starting off with a positive reputation.
Ford a/c heater
I have a 2006 motorhome on a Ford chassis, believe it's F53 or P53?. Anyway my blower quit working also. The strange thing is, when I turn the control **** to any position for a/c or heat the back lighting comes on behind the panel and nothing works. If I switch on my headlights the back lighting goes off. My headlights and other dash lights work but my a/c heat panel still does nothing?
Doug
Old 12-04-2010, 04:16 PM
jeepman_79's Avatar
try this
Did you try turning your headlight switch on and off several times. I don't miss this problem glad I traded that truck in. Good Luck
Troubleshooting AC + Heater TexanAmmo 1987 - 1996 F150 & Larger F-Series Trucks 53 02-08-2017 09:08 PM
Clicking. Alex from GA Explorer, Sport Trac, Mountaineer & Aviator 7 12-27-2016 06:59 AM
'05 Rear Heater/AC hissing sound??? vanvoorenfamily 1997-2006 Expedition & Navigator 3 12-08-2011 12:47 PM
Vacuum Plumbing to Heater\AC Control ??? gjfpilot 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-22-2004 04:28 PM
CD Player: OEM Trade-Out Tips '92 - '94 Jtrekker Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 08-05-2003 08:52 PM
Tags
05, 1983, ac, control, excursion, f150, f250, ford, heater, heaterac, intermittent, lights, panel, unit, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
