ihave a v10 that will not stay running unless i keep my foot on the gas pedal. sometimes it will start and run fine other time it will start and then shut right off. will not just idle? any help
I had the same problem! I was ready to replace my IAC, when a Ford Tech suggested I check all of my vacuum lines, so I did and I had a few cracked ends, cleaned them up and trimmed off the bad and shes runs like a champ now!
Not saying it will solve your problem, but it might help...
