driveshaft balance
driveshaft balance
So tomorrow the truck is going in for a realignment because the first time ford did it the truck developed a pull so I want them to fix it, I figured I might have the driveshaft balanced while I'm there, it shouldnt cost more than $30? yesterday the vibrations seemed to be coming from the rear and was shaking the seat, the U joints are new, would these be symptoms of an unbalanced shaft? no weights are missing on it
I never saw a Ford dealer that can ballance a driveshaft and I've worked at a bunch of them. I seriously doubt that is your problem unless you can see it is visibly bent or something is loose on it. Check your spings, bushings and shackles on the back. Shocks too. You could also have a bad tire. I'd definitly be looking at other stuff before a driveshaft if it looks ok.
Try doing a search on this forum for "death wobble" and do some reading on that to see if that sounds like your problem. It's a common problem with these trucks.
One other thing, if a steel belted tire is allowed to run out of balance for a while sometimes the bouncing can cause the steel belts to shift slightly. You can then balance it till your blue in the face and still not stop the bouncing even tho there will be nothing visably wrong with the tire.
Since your tires were off recent;y did you check to make sure all the lugs are tight.
This is not the death wobble thing. It sounds like it's doing it all the time. the "death wobble" is usually after hitting a bump or a dip when the truck gets a mind of it's own. That's something else entirely.
No they said everything was fine, I also had the truck aligned and balanced at the ford dealer not some side shop downtown, this is not a vibration that occurs after hitting a bump, you start to feel it at 30mph in the steering wheel mostly, then gets worst at 50-55mph then starts to calm down, trans mount and motor mounts are fine, my rag joint was fine, new inner and outer tie rods, ball joints are fine, lugs are tight, new driveshaft u joints, all 6 tires are new and inflated at the same exact psi, steering stabilizer is brand new, I'm about ready to run it off a cliff, doesnt have anything to do with abs system, no brakes are hanging, and is not transmission or driveline related because I can let off the gas and it still does it, drive with od off and it does it, shift to N and it does it
Edit: it is a F350
Edit: it is a F350
yes i has the d60 up front, what is the track rod? not the same as drag link right? but the diagonal bar behind the draglink?
Edit: also the truck does need new shocks all the way around, these ones are original and has rust on the surface but no signs of fluid seeping from them, just whenever I hit a road bump I fly up into the roof
The track bar is on the passenger side behind the axle. Bolted to the axle and the frame. It keeps your axle in place side to side. If the bushings even look the least worn replace them. I hate alignment shops! I did that as my specialty for a long time and you all wouldn't believe the stuff I would fix that other shops just let go and aligned anyway.
It never should have been aligned with anything loose on the front end. It looks like they did though adn just ripped you off.
Heres a quick lesson on checking the front end.
For ball joints, jack up each front tire a couple inches then put a big prybar or pipe under each one and try to jack the tire up and down while someone watches the joints. Any movement at all means they are bad.
For tie rod ends and drag link, with the wheel jacked up on one side grab it at 3 and 9 oclock and shack right to left with someone watching all the joints. Any movement is bad. Feel how the wheel bearings are too while the wheel is up. Shouldn't be any movement at all.
And check your wheel torque. Should be at least 120. I do mine to 150.
That's something else noone ever does in shops getting paid flat rate.
If you feel it in the steering wheel then it is in the front end.
Also look again at your spring bushings and especially the shackle bushings. You may have to drop the front end of the front springs and the rear end of the back ones to see those but I will bet you the bushings are wasted on the shackles if they are original. That is the leading cause of most ride problems on these. That and shocks.
