Dash shakes
Dash shakes
I know that someone out there must have had this problem, as my '93 Bronco did the same: my '94 Bronco's dash shakes around quite a bit on rough roads. Just the right side, the driver's side doesn't seem to move. Is this normal, and is there a fix? I've looked, but can't seem to find a cause.
Great topic, snowdog!
My '94 Bronco's right side of the dash started shaking up & down on rough roads last summer. Found a sliver of plastic on the floor, figured something broke. Too hot to spend time looking under a dash then, will do it in winter... I forgot all about it last winter. I better do it this winter, before it shakes enough to break off the [I]next[I] mount.
I didn't realize it was that common of a problem!
From FORD you get one steel, double angle bracket, three pop rivets, and a set of installation instructions all in a box.
They did have to order it and it cost $18.72 plus Tax for a total of 20.09 as of 11/04/05.
It took about two days to get it and with out this number they did not know what I was talking about.
Part # F4TZ-1504366-A
Instrument Panel, Loose Right Hand Attachment to Cowl Side TSB 94-15-13 by Ford for 92-94 Bronco, F-150-350 Series
NOISE—“RATTLE” COMING FROM RIGHT SIDE OF INSTRUMENT PANEL
FORD: 1992-1994 BRONCO, F SUPER DUTY, F-150-350 SERIES
ISSUE
A “rattling” noise may come from the right hand side of the instrument panel. This occurs when the
cowl attachment cracks causing the instrument panel to become loose.
WARRANTY STATUS: Eligible Under The ACTION Provisions Of Bumper To Bumper Warranty Coverage
Install a metal bracket to the right side of the instrument panel to secure instrument panel to cowl.
OPERATION DESCRIPTION TIME Refer to Instruction Sheet #6551. Install Bracket 1.0 Hr.
Service Kit (F4TZ-1504366-A) consists of:
• One (1) bracket
• Three (3) rivets
• One (1) Instruction Sheet
#6551 OASIS CODES: 107000, 702300
The TSB:
http://www.thedieselstop.com/faq/949...les/941513.pdf
ISSUE
• One (1) bracket
• Three (3) rivets
The TSB:
Yesterday morning I took a quick look at mine. Over by the door, between the dash and the top of the side cowl panel trim that goes up for a bit next to the dash, I could see a bolt head. And black plastic under the bolt head. Black plastic that was broken on both sides of the bolt head!
And today I read subford's post, with link for the kit, right where mine is broken!
Thanks subford!!!
Thanks subford!!!
I got the kit on mine. It works great. To install it you'l have to take the whole dash loose, and swing the passenger side back a little, but its not that bad. I left the bolts installed on the driver side and just loosened them and removed the bolts on the passenger side. I had mine repaired in about 15-20 minutes.
