Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-31-2010, 06:31 PM
greywynd greywynd is offline
Garage is empty, add now
greywynd is starting off with a positive reputation.
Starter Solenoid
Here's the scoop. On occasion the dually has been sluggish turning over, crank a few seconds, the starter picks up speed, and then it'll fire. Look over the battery cable connections etc last night, they all seem good, no sign of cables overheating etc, grounds are clean, booster cables from battery to battery made no difference.
I look at the connection at the solenoid, it's so-so, not dirty enough that it is jumping out as the culprit, but, enough that I decide to pull it apart to clean it. As I go to undo it, the plastic end on the starter solenoid tries to turn. I use a piece of wood to block it to prevent turning, take the cable off, clean it all up, and put it back on. I try starting it, and it turns over slower than before?
Usually I leave the starter solenoids and starters themselves to an automotive electrical guy nearby, so I don't know what/how the connections are inside this thing. With it having spun like that, is it toast, or repairable, or what? Does it make sense that there could be a connection in the solenoid causing the lazy starter issue?
Batteries are a matched set approx 14 months old, I put the charger on them to top them up just in case, and will check voltage in both before trying again (maybe later this evening). I don't have a load tester, or I would test them that way too, just in case a cell has puked, if it does turn out to be a battery issue, at least they are still under warranty.
__________________
2001 F250 Superduty, 6.8V10, 2WD, auto. The 'family' truck.
1989 F350 2wd C6 N/A 7.3 Diesel Dually w/flatbed dump, retired with a broken frame rail.
1991 F350 4x4 E40D, N/A 7.3 Diesel, SRW, Crewcab, now with Meyer plow.
1990(?) F350 4x4, E40D, N/A 7.3 Diesel, with Meyer poly plow, needs a body swap.
1991 F250 4x4, E40D, N/A 7.3 Diesel, 'the runaway'
1991 F250 4x4 C6 N/A 7.3 Diesel, parts truck
  #2 (permalink)
Old 07-31-2010, 06:46 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
I would replace that solenoid myself. Also check the connection pionts at the fender. Make sure they are clean and tight as well.
__________________
DON'T BUY IT ..FAB IT!!!!
81 BRONCO 6.9 IDI, ARP headstuds, 3" dual straight pipes, isspro pyrometer, T18 4 Speed, 10.25 rear, d60 front, 4:10 gears, 37x12.5x16.5 wrangler m/t's (humvee takeoffs), 4" body lift. I am building the Bronco Ford should have!
Kentucky Chapter Member
  #3 (permalink)
Old 07-31-2010, 07:06 PM
Yep, I cleaned the connections at the solenoid on the fender. I was hoping I would find an obvious poor spot, but no such luck.
__________________
  #4 (permalink)
Old 07-31-2010, 08:32 PM
kenpobuck's Avatar
It could also be corrosion inside the cables themselves. Rupe just had that problem. Also check both grounds from the battery - post to the block.
__________________
  #5 (permalink)
Old 07-31-2010, 08:35 PM
Yea, I was just thinking a bit ago that I could try an ohm meter from the cable end to cable end to see if they show an increased resistance. I should look to see what I have for spare cables, I know the one parts truck they are junk, but I may have a decent spare in my parts collection.
__________________
  #6 (permalink)
Old 07-31-2010, 08:45 PM
kenpobuck's Avatar
I went to the upull it this morning to snag my core support and the truck I pulled it from had those cheap clamp on cable ends. I wonder how long those pos things lasted lol?
__________________
  #7 (permalink)
Old 07-31-2010, 11:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
I actually find that the starter problems are usually the starter mounted solenoid, not the starter.
On a few I have seen the connection from the solenoid into the starter melt, which a new solenoid would not correct.
Those contacts in the solenoid do get cooked/pitted.
When you turned the post, now they are not making a great connection since the wear patterns on the contacts are not lining up.
But since I bought a lifetime warranty starter, changing the solenoid would void the warranty.
So when mine starts getting weak, I just get a new starter.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #8 (permalink)
Old 07-31-2010, 11:34 PM
poocher pup poocher pup is offline
2002 Audi A6
My Garage
poocher pup is starting off with a positive reputation.
I agree with what dave said as my last starter problem was between the solenoid and starter motor itself.
  #9 (permalink)
Old 08-01-2010, 12:18 AM
87crewdually's Avatar
87crewdually 87crewdually is online now
2005 Ford F-350
87crewdually is gaining momentum as a positive member of FTE.
This is actually Toyota but same principle. When you turn your key the electro-magnet pulls in the plunger of the solinoid which then has a disk that makes the contact for the starter motor. If the contacts are burnt or shifted the starter will drag as you describe.
Click the image to open in full size.
__________________
IN SERVICE: 05 CCD XLT 6.0 4x4, 4" turbo back, ScanGaugeII, Egt Gauge, 92g Fuel Transfer Tank/Tool box.
RETIRED: 87 CCD, 6.9 Banks Sidewinder turbo & ARP studs, Turbo pump & G code injectors, str8 Pipe out the side, worked C-6 with Laycock/GearVendors Overdrive, & 4.56R&P
  #10 (permalink)
Old 08-01-2010, 06:15 AM
Okay, since I just had this rebuilt a couple years ago, I'll pull it off and see if I can throw a spare one on for a test. If that seems to help/fix the problem, I'll take it back to my rebuilder and get him to swap the solenoid. I didn't get a chance to do anything with it last night, so when I do get back to it, I'll also try checking the battery cables out too.
__________________
  #11 (permalink)
Old 08-01-2010, 08:27 PM
So tonight I checked all the battery cables with an ohmmeter, from the negative terminal on each battery to the top of the AC compressor was 0 ohms, and from each positve terminal to the small wire on the fender solenoid was also 0. (This was with the positive cables disconnected from the batteries.) Dug out my spare starter, looks like it's quite possibly an original starter, filthy dirty, connections were rusty, mounting surface corroded and caked with a scale of some sort.
Cleaned it all up, and put the two side by side, and grabbed my booster cables to do some testing. The one I took off? It turned so slow you could hear the reduction gear teeth 'chattering'. The spare starter almost torqued itself off the bench! Tested the solenoid on the spare before putting it on, (nothing worse than getting something on and it not work!) and seemed ok.
Fought to get it back into position (wouldn't an extra 1/2" of room lengthwise be a whole lot nicer??) and got it bolted in. Hopped in the truck, let the glow plugs cycle a few seconds, and it fired right up!
So.... someday next week that starter will be going to visit the rebuilder again...... I do have to wonder if maybe there is something dragging in the gear reduction side though the way it sounds.
__________________
  #12 (permalink)
Old 08-01-2010, 09:48 PM
1997 Ford F-350
My Garage
If you look at the two outer contacts in that picture you can see exactly where the problem is.
The contact on the left is worn so thin and only has a tiny bright spot that was actually making contact.
I bet that one was really dragging before the tear down.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #13 (permalink)
Old 08-02-2010, 08:13 AM
tjc transport's Avatar
tjc transport tjc transport is offline
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i have found that when the starter speeds up as it cranks, that the starter itself is usually bad.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #14 (permalink)
Old 08-02-2010, 10:03 AM
Well, I don't know if it is the starter or the solenoid, I'll take it out to him one day this week and hang out while he tears it down to find out. What I do know is it's good to know that the cables etc are good still, and it's running again!
__________________
  #15 (permalink)
Old 08-02-2010, 12:45 PM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
1986 Ford F-250
elinmon1976 is starting off with a positive reputation.
I have seen those reduction gears sheared off or sometimes shattered all todether. It is rare, but then again I have built more than my share of these starters....
__________________
'86 F-250 4x4, 6.9 diesel (Ruby Sue)
Home-made flatbed, Diamond plate Aluminum over wood.
"If a hammer won't fix it, you've got an electrical problem..."
Tags
1989, 73, 73l, 90, bad, clicking, diesel, econoline, f250, f350, ford, make, selonoid, solenoid, solenoids, starter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
