Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
New! Use your Facebook to securely log into this site, click logo to login
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-31-2010, 02:44 AM
79'Ranger's Avatar
79'Ranger 79'Ranger is offline
79'Ranger is starting off with a positive reputation.
engine sounds fine, but no power?
Ive been lurking around this forum for some time and looking at all these beautiful beasts of trucks has forced me to fix up my parents old 79 f100 thats been sitting for about 7 years.
The truck starts fine but idles a little rough, i chalked it up to sitting for so long. My main concern though is that there isnt any power when i hit the gas, it just chugs and chugs, i cant get over 25mph.... Ive been searching around but i cant really find anything about this. I just pulled the tanks and cleaned them, did the spark plugs and im about to put on the new carb. But if that doesnt work i dont know what to do next. Valves? Rings? Main bearings? (hopefully not)
Its a stock (for now) 302 rebuilt about 20 years ago if that helps at all.
So my question to the kind people of FTE is... What are the most common problems for lack of power like this? Any and all advice would be much appreciated.
-JJ
  #2 (permalink)
Old 07-31-2010, 02:57 AM
arctic y block's Avatar
arctic y block arctic y block is online now
arctic y block has a very good reputation on FTE.arctic y block has a very good reputation on FTE.arctic y block has a very good reputation on FTE.arctic y block has a very good reputation on FTE.
-JJ
See what happens after the new carb is on. Old one is prolly sucking air from old gaskets and plugged with varnish and like that. Are the brakes dragging? Is it hitting on all 8? Whats the compression? Stuck valves, Rings? Do you got smoke. WOW i better say do you got smoke out the tail pipe or the pot heads will be calling ya.
__________________
62 UNI Wide Window SWB 390 C6
66 F350 Flat Bed Hi Pro 427 4 speed
7 4X4 Rangers 84 - 89
55 Fairlaine Town sedan 272 Ford O Matic
Show all the luv ya can while ya can. Or one day ya may be alone
Don't just Modify it Fordifiy it
  #3 (permalink)
Old 07-31-2010, 03:09 AM
79'Ranger's Avatar
Haha... Ya i got smoke... and the tail pipe is spitting some too . Only kidding, ha! But ya there was smoke. My dad had a compression check done right before it was parked but i cant remember what the results were, im sure it wasnt good, ill have to ask him. We did the brakes a few years ago, so they shouldnt be a problem. Everything is firing fine as far as i know.
Im just trying to get some second opinions, gain some knowledge and whatnot
  #4 (permalink)
Old 07-31-2010, 04:18 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 is gaining momentum as a positive member of FTE.mikeo0o0o0 is gaining momentum as a positive member of FTE.
See how it runs with the new carb. If okay, fine. If not, first check your timing. Retarded timing will cause a no power condition, then run a compression check. If compression is bad in some cylinders those issues will need to be addressed. Check for stuck valves and/or bent pushrods. If compression is good and even (20% max difference between highest and lowest cylinder) start doing normal trouble shooting. Check for vacuum leaks including the brake booster (if power brakes) and under the dash (if factory A/C).
  #5 (permalink)
Old 07-31-2010, 02:10 PM
merccougar93's Avatar
merccougar93 merccougar93 is offline
merccougar93 is starting off with a positive reputation.
if you still have the same problems with the new carb, you might have buildup in the intake runners and in the heads from it sittn for that long. Dirtdoggers and other flying pests love places like that. Might have to blow them out and new valve seals most likely. possibly gummed up fuel lines also. thats what id check first.
__________________
Chris 1979 F350 330FE, NP435 LWB
1978 F150 351M 4x4, 3 spd AUTO, SWB
  #6 (permalink)
Old 07-31-2010, 10:04 PM
justforkicks's Avatar
justforkicks justforkicks is offline
justforkicks is starting off with a positive reputation.
mine was doin the same thing when i first got it 3 years ago. i just stomped the gas down a couple times and spun a few donuts and everything cleared fine. i also put new plugs and cleaned the carb out afterward. gotta blow the carbon out from time to time lol
__________________
'Sac
77 F150 4x4 351M, NP435, NP205, Dana 44, 9", 3.50's
4" lift on front, 6.5" lift on rear. 2.5% rear tint, 35% sides and tint strip
  #7 (permalink)
Old 08-01-2010, 03:24 AM
79'Ranger's Avatar
Ran into some problems with the new carb, but will update when i get it sorted out. Thanks for the info guys, much appreciated.
-JJ
Tags
engine, forum, power, runs, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
