Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
New! Use your Facebook to securely log into this site, click logo to login
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-30-2010, 05:24 PM
havns3's Avatar
havns3 havns3 is offline
havns3 is starting off with a positive reputation.
need quick answer been searching but havent found the answer
i got my edge insight installed and have made 3 short trips so far 20 to 30 miles each. my ECT reached 190. my EOT Went as high as 222 on the last trip A/c on max about 95 degrees air temp. so to by me some time i am thinking i need to diconnect my egr valve until i can fix it properly. can i discoonect the valve at any time and it will be closed or do i have to wait for the enigine to cool down?
__________________
2004 f-250 SC, LB[with the 6.0 diesel. edge insight.
dieselsite coolant filter .egr blocked, new oil cooler, updated turbo tubes, new FICM , duralast gold batteries 1000 cca, new altenator. replaced my 1994 f-350 crewcab dually. wife driving a 2006 mustang convertible. daughters in the 2005 ford focus my youngest wants the dually back
  #2 (permalink)
Old 07-30-2010, 05:47 PM
Locatoraaron's Avatar
Locatoraaron Locatoraaron is offline
Locatoraaron is starting off with a positive reputation.
Probably shouldn't matter but wait until morning, prior to starting and disconnect it, when its nice and cool. Do you have any smoke at idle?
My temps are continually higher than you have posted. I would love to delete my egr and get an after market oil cooler. just need to put on 32 k miles until warranty is gone. Then its upgrade time. Good luck guy
  #3 (permalink)
Old 07-30-2010, 05:51 PM
SHAWN056.0's Avatar
SHAWN056.0 SHAWN056.0 is offline
SHAWN056.0 is starting off with a positive reputation.
Disconnecting the egr is not gonna buy you any time. If your oil cooler is clogged it's clogged. You could try flushing your coolant with vc-9 and distilled water. There's some right ups on how to do. Good luck.
__________________
4" Magn turbo to single 7" stack
6" Fabtech Lift, 35x12.50 MTZ
Airdog A/W seperator, ITP RR, EGR Delete
ARP Studs, Coolant Filter, B/EGT/FP Gauges
Fumoto DV, Amp Research, CCV Reroute, 05 F250
  #4 (permalink)
Old 07-30-2010, 07:13 PM
havns3's Avatar
my thoughts was that if i shutt of the egr exhaust to the egr cooler that even if the oil cooler plugged up it wouldnt cause the egr cooler to come apart. i just flushed out the coolant a month ago. no other syptoms no coolant loss or puking just this readings from the insight
__________________
  #5 (permalink)
Old 07-30-2010, 07:17 PM
bismic's Avatar
bismic bismic is offline
bismic has much to be proud ofbismic has much to be proud ofbismic has much to be proud ofbismic has much to be proud ofbismic has much to be proud ofbismic has much to be proud ofbismic has much to be proud ofbismic has much to be proud of
The coolant to the oil cooler is not flowing properly because the oil cooler passageways on the "coolant" side are plugged. You do not want to operate your vehicle with the oil not being cooled properly. Nevermind the EGR cooler.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20;DieselSite Coolant Filter; High Idle Mod;HFCM Plug;Zoodad;Accufab Elbow;RACCCV6000 filter; JimmiJammers;Ravelco;SynchroMax Transfer Case;Fumoto Valve;Harpooned fuel tank;Line-X;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;Stanadyne Performance & B2;PIE adapter;PIAA 24" ww blades;updated EGR valve;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;BBmod;DashDAQ;PHP FICM;Dieselsite boots;DCPower190A;Bilsteins;& misc bling
  #6 (permalink)
Old 07-30-2010, 07:26 PM
cheezit's Avatar
cheezit cheezit is online now
Tech
cheezit has a great reputation on FTE.cheezit has a great reputation on FTE.cheezit has a great reputation on FTE.cheezit has a great reputation on FTE.
http://www.ford-trucks.com/forums/97...egr-valve.html
worth a read.
also disconnecting an egr valve will not change anything at all
__________________
Ford Senior master tech, gas and diesel.
ASE Master Tech, L1 certified.
2006 f250 cc swb fx4 6.0
mods arp,egr delete, tuned.
  #7 (permalink)
Old 07-30-2010, 07:52 PM
havns3's Avatar
i guess i will be reading up on the oil+ egr cooler replacement threads then. i really like this truck but i cannot do not think i can afford all of the BS just to keep it running.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
