Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-30-2010, 05:05 PM
armstrongfordtrucks armstrongfordtrucks is offline
1997 Ford F-350
My Garage
armstrongfordtrucks is starting off with a positive reputation.
Width of drw 2003
Can anyone tell me the width of a drw 2003 F350? I have a 9' wide door and I'm not sure whether or not it will fit through. Thanks.
__________________
ARMSTRONGFORDTRUCKS
1975 F-250, XLT, 4X4, 460 BORED 40 OVER, STRAIGHT UP TIMING, EDELBROCK INTAKE AND CARB, AUTOMATIC, FACTORY AIR, CRUISE. (SOLD)
1997 F-350, XLT, 4X4, PSD, AUTOMATIC, MEYER P.A. PLOW, DUMP BED.
  #2 (permalink)
Old 07-30-2010, 05:08 PM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
FORD THE ROCK CRUSHER
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
not sure on the ### but if the tow mirror's make it though without folding up...you should be all set..no legal vehicle should be over 8 ft wide..
__________________
Early 99 7.3 F350 auto,
on the shelf ready to go in,APR head studs,910 springs with shim kit,adrenaline,fuel tank sump with a fuel lab 41402 fuel pump,5/8 feed lines to the injectors. 3/8 for the return,38R,TS chip,on somebody else shelf
250/100% hybrids,stage I performance cam,
exploded view of a 7,3 << more pix of my truck
  #3 (permalink)
Old 07-30-2010, 05:41 PM
Philip Berardi's Avatar
Philip Berardi Philip Berardi is offline
2000 Ford F-250
Philip Berardi is gaining momentum as a positive member of FTE.Philip Berardi is gaining momentum as a positive member of FTE.
Quote:
not sure if this helps at all but one of our work trailers is 102'' and it barley...i mean BARLEY gets through the toll booth. i know the dully is very very similiar thats what we pull it with
__________________
Phil Berardi - 2000 F250 CC 4x4 / Warn Hubs / GSP Gauges: Pyro, 60 bost, Trans temp, Fuel pressure / Dual BT / Muffler delete / 4" Downpipe / 4" Straight pipe back / S&B Cold air intake / DP tunner: 1100 idle, 80 econ, 120 race, Loop idle / CCV mod / 50 cent mod / Running lights / Interior Cab lights / Foil Delete / WGD / 5% tint / Plenium inserts
  #4 (permalink)
Old 07-30-2010, 05:45 PM
trailers are under a different law..
__________________
  #5 (permalink)
Old 07-31-2010, 01:04 AM
clintbonnie clintbonnie is offline
clintbonnie has a good reputation on FTE.clintbonnie has a good reputation on FTE.clintbonnie has a good reputation on FTE.
The mirrors on my 99 measure 106"... the rear fenders are about 98"
__________________
Clint... Early 99, F350, 4X4, Auto, DRW, S-Cab, Gauges, Diablosport 60 HP, OilGuard, Tru-Cool, 5% Biodiesel, Shell Synthetic 5w40, Western Diesel TurboRamAir, MagnaFlow Exhaust, SSHPX, CCV Mod, Fuel Line/Tank Mod., Speed Bleeders, Bilstiens....
  #6 (permalink)
Old 07-31-2010, 05:56 PM
1997 Ford F-350
My Garage
thanks to everyone.
__________________
ARMSTRONGFORDTRUCKS
  #7 (permalink)
Old 07-31-2010, 09:39 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is online now
rbaker6336 is a name known to allrbaker6336 is a name known to allrbaker6336 is a name known to allrbaker6336 is a name known to allrbaker6336 is a name known to allrbaker6336 is a name known to all
I have put my truck through a 9' door even with the flair kit that came on it.Originally it was 104" at the rear fenders.
I took the rear section of the flairs off a good while back so I could get through drive throughs
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install, DooDad???=(dfuser ram air)
'98 Grand Cherokee, '86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
