what are symptoms of crankshaft sensor going out? - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 07-30-2010, 06:02 PM
britt britt is offline
britt is starting off with a positive reputation.
title says it all.....2000 v-10. getting a stumble at part throttle..fresh tune up, new boots and even swapped out the final four original coil packs. new maf, tps and fuel filter swapped a couple of months back. running 87 tow haul tune at present.. sorry but stumble seems to describe it best............thanks
Old 07-30-2010, 06:11 PM
p-nut p-nut is offline
p-nut has a good reputation on FTE.p-nut has a good reputation on FTE.
Put your stock tune back on and see if it goes away.
Old 07-30-2010, 06:38 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Usually a crank sensor will make it stall. Start it back up, it runs fine until the next stall.
Put the stock tune back and see if it still does it.
Old 07-30-2010, 08:40 PM
fordmdb's Avatar
fordmdb fordmdb is offline
PREMIUM SPONSOR
fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.
Theres nothing in the tune that will cause stumbling and missing. Something else is going on with the truck. The tune might just bring out the issues more than stock. Your truck as higher miles did you ever do a compression check on all cylinders? Also are the battery cables good and clean with a good ground to block I have seen bad battery cables create many issues too.. Can you take a video of stumble?
__________________
Custom Tuning for F-E-Series Engines 6.8L V10 / 5.4L V8 / 4.6L V8 / 6.2L V8 / 5.0L V8 / 3.7L V6 / 3.5L V6 / 3.5L EB / 2.7L EBand more!
SCT Custom Tuning Dealer
www.5startuning.com email me here:sales@5startuning.com 843-536-1244
https://www.facebook.com/pages/5-Sta...92086367552400
Old 07-30-2010, 09:04 PM
when i had it scanned at dealership, all cyl were within specs of each other...the tech told me it was in good shape. guess only to know for sure is do a leak down test? thanks for the help guys....not a major issue, just frustrating as hell.......
hpop questions knutson28 6.0L Power Stroke Diesel 20 07-23-2014 04:34 PM
Fuel Injection Question sa-jimd 1987 - 1996 F150 & Larger F-Series Trucks 13 06-02-2014 11:40 AM
94 e350 stumble in idle? llh 1968-2013 Full Size Vans 6 11-27-2011 11:05 PM
coil packs oem or aftermarket britt Modular V10 (6.8l) 12 08-08-2010 11:10 PM
Fixed 1/2 Throttle Stumble! Spudco Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 04-12-2003 08:47 PM
Tags
10, 2001, 60, 73, bad, camshaft, crank, crankshaft, f250, ford, location, sensor, symptom, symptoms, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
