Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-30-2010, 04:40 PM
ronbo57 ronbo57 is offline
ronbo57 is starting off with a positive reputation.
Engine miss
1998 Ford F150 all stock 4.6 . Engine miss. Original code said misfire in 2 and 4. Replaced all plugs with new Champion platinum. Still have problem, but much better. Seems to smooth out when warmed up good, but definite miss when loaded up (Stomp on gas or speed up quickly) Replaced driver side coil pack, still has problem, no check engine light. Parts guy said run all fuel out (as it is over a year since last ran) Have not replaced plug wires yet. I will run it tonight and look for the obvious. Next step I plan is run the fuel out and replace the fuel filter put in some higher octane, unless someone has experienced this problem and has an answer. Thanks in advance. Ron
  #2 (permalink)
Old 07-30-2010, 10:57 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 is gaining momentum as a positive member of FTE.
With the truck setting that long, the gas could be stale.
Do all the normal maintance for fuel filter, new gas, water absorber, even fuel injector cleaner but not all at the same time.
Then see what you have before going back to ignition checking the plug wires etc..
BTW some will tell you not to use the plugs you put in.
No problem, if you did the job correctly and used grease inside the boot tips making sure the boots and internal springs set down on the plugs and inspected the boots, they should be fine.
Good luck.
Tags
engine, ford, high, mis, miss, speed, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
