Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 07-30-2010, 02:51 PM
Speedjester Speedjester is offline
Garage is empty, add now
Speedjester is starting off with a positive reputation.
Radiator cap???
As some know I have just purshased a 2005 f350 PSD.. Then took it to dealer for service.. Everything was OK according to dealer cleaned and flushed coolant, tranny fluid, fuel filter and oil change(see my other post)..
Well the dealer overfilled it a bit so on my 200+ mile trip.. I stopped at a rest stop and noticed that the bottle had puked very little(funny though the fluid was no where near the cap... so wiped everything down and set off again...Upon my arival at my destination I popped the hood and heard a hissing noise coming from the Degas bottle cap(the collant wasn't overheating and was well below the cap)little experiment parked the truck on a decline and shook the bottle a little and coolant puked out a little.. So my question is should the cap vent when its not overheating.. .. Because Im wondering if with the cap venting and the coolant sloshing around in the bottle could cause the loss of coolant??? Should the cap vent when the engine is off and not overheating???( I also noticed that the everso slight downward pressure on the cap stops the venting)
Oh yeah one more thing this morning cold (overnight) When I opend the cap It released pressure..So I believe the pressure isnt leaking down significantly..
Also want to mention there is no smoke what so ever and strarts immediatly..
Thank you
Thoughts and opinions
  #2 (permalink)
Old 07-30-2010, 03:25 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Ford says that once the degas bottle cap "relieves", then you need to replace it.
If you are worried about leaking head gaskets, then you can get a kit that analyzes for combustion gasses (from the degas bottle). Napa has them.
__________________
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
  #3 (permalink)
Old 07-30-2010, 05:36 PM
My local mechanic used what looked like a test strip to check it when I brought it by his place to take a look at it.. Said it was ok..
  #4 (permalink)
Old 07-31-2010, 04:37 PM
I am not familiar with Diesel engines... But have noticed some odd things like when you first start the truck it seems to draw from the degas bottle then after it gets hot it flows back into tank and after it cools stays in the same place as hot with maybe a little fluctuation... Then when cold It starts and then level goes down then back up..
I have never noticed this on my Gas cars... Is this normal...
  #5 (permalink)
Old 07-31-2010, 05:07 PM
69cj 69cj is offline
69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of
A new upgraded cap is only about 7 bucks. Cheapest thing you could try.
__________________
"05 F-250, 6.0, CC, LB, 3.73, 4 X 2, Lariat, with coolant filter and Bilstein shocks, Magnefine p.s. filter, Ford fuel press. spring upgrade and ScanGauge ll. S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
2007 FHLP H.D. Road King
2007 Thor Jazz 5er, 11k dry weight, 31'
173rd Abn. RVN.
  #6 (permalink)
Old 07-31-2010, 10:53 PM
Benchwrench's Avatar
Benchwrench Benchwrench is offline
Benchwrench has a very good reputation on FTE.Benchwrench has a very good reputation on FTE.Benchwrench has a very good reputation on FTE.Benchwrench has a very good reputation on FTE.
This doesn't work if you add coolant to the system because of puking. The new coolant will dilute any HC found.
In my case, I added a considerable amount of new coolant after the pressure cap vented so I wasn't able to try it out.
I think my egr cooler is bad but will have to remove it to find out.
Right now the truck bellows smoke after each and every stop light.
__________________
"Because Stock is not an Option".
  #7 (permalink)
Old 07-31-2010, 11:01 PM
bismic's Avatar
Quote:
Good point!
__________________
Mark
  #8 (permalink)
Old 08-01-2010, 09:28 AM
If your egr coolers bad so's the oil cooler.
__________________
173rd Abn. RVN.
  #9 (permalink)
Old 08-03-2010, 07:53 PM
Well changed cap and all is good ...300 miles and no coolant puking also coolant didn't fluctuate like it did before .... I thank the diesel gods.... and everyone here for there help...
Tags
2003, 2005, 2006, 60, cap, coolant, diesel, f150, f250, f350, ford, located, powerstroke, radiater, radiator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
