CLUTCH RETURN SPRING - Ford Truck Enthusiasts Forums
Old 07-30-2010, 02:33 PM
woodhd woodhd is offline
woodhd is starting off with a positive reputation.
I need some help with finding a clutch return spring. I have a 1965 F100 2wd. Im missing the clutch return spring and no one seems to sell a replacement part for it. Does anyone know of some where they sell the parts or of another that will work with this set up. What I can find is the spring should ba 4.6" long with 35 coils. Any help would be great. Thanks
Old 07-30-2010, 04:45 PM
airharley's Avatar
airharley airharley is offline
airharley is gaining momentum as a positive member of FTE.
Where in the linkage is the spring located, on the side of the bellhousing?
Old 07-30-2010, 05:43 PM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Don't recall seeing a spring on clutch asssembly on my 65, apparently the spring on the brake pedal assembly in the cab provides sufficient tention. Appears from the link a spring on certain models can run from 'Z' bar to clutch arm, perhaps more knowledgeable member can advise. If too sloppy may want to consider replacing the plastic and felt washers on the 'z' bar, make sure to pack with grease.
http://i300.photobucket.com/albums/n...chAssembly.jpg
Old 07-30-2010, 07:37 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
The spring goes between the clutch throwout fork and the Z bar shaft...its basicly an anti rattle as well as to keep the fork in the end of the adjuster tip.
There are some new ones close to you...the p/n is C7TZ7523F JST Automotive in Lebanon, Tn has 3 of them..their number is 615-443-3086
cs65
Old 07-31-2010, 05:38 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Look at the "generic" pic you posted (the release spring is # 7523) then crawl under and take a look-see.
At the end of the clutch fork is a small hole, one end of the spring fits into that...then attaches to the clutch equalizer bar.
Same-o same-o all 1965/66 F100/250 2WD's. All trucks have one a these, but mount differently on 4WD's, F350's and etc.
Under the dash, mounted on the clutch/brake pedal bracket...then to the clutch pedal is the Clutch Pedal Lever Assist Spring (C5TZ7A600B). This is not...IMO, what the OP is asking for.
Old 07-31-2010, 10:15 AM
Did notice item #7523, for past 40 yrs. been looking at the truck from the underside more often than want to admit; the item in question aint there, nor has it ever been. Perhaps I keep too much tension on the clutch arm assembly but it's taunt, not sloppy, and been working fine over these many years. Would think I should have learned by now, particularly with the upgrades and modifications, what applies to my 65 does not necessarily apply to others, I still have to learn to include a disclaimer in the future. .
Old 08-10-2010, 03:35 PM
Thanks for the post. Sorry it took so long to respond. Ive been sick. If the spring is only for tension then what makes the pedal come back up. when I push the clutch pedal in it wont come back up.
Old 08-10-2010, 03:43 PM
does it stay on the floor or only partially return ??? If its always been like this then the clutch may need adjustment...if clutch adjustment is at the end of its range the clutch may be in need of replacement...I know mine is nearing the end of its life as it doesnt start grabbing until the topend of the pedal travel...If this is a new rig to you it may have the wrong clutch adjustment rod in it also.
- cs65
Old 08-10-2010, 03:53 PM
It just stays on the floor. It is a new truck to me. It was working just fine until the spring they had on there broke and I lost the clutch adjustment rod. I bought a new rod from npd and got a spring for a 57 to 60. I put the new rod in and the spring and know when you push the pedal it stays on the floor.
Old 08-11-2010, 05:50 AM
Quote:
Originally Posted by woodhd View Post
I bought a new rod from npd and got a spring for a 57 to 60. I put the new rod in and the spring, and now when you push the pedal it stays on the floor.
The correct clutch adjustment rod for 1965/66 F100/250 2WD's (& 1967/76 F100/350's) is composed of two separate parts.
The section that attaches to the clutch equalizer bar is 3 29/32" long, has a threaded end.
The extension of the clutch rod butts up against a dimple of the clutch fork (clutch release lever) and is 2 27/32" long, has a pointed end. There are no threads within this extension.
The extension slips over the threaded end of the rod. Two nuts are used to keep it in place once the clutch is adjusted.
When this rod was available from Ford, it came with both parts (DOTZ7521C). The extension only (DOTZ7A504A) could be bought by itself...because when the clutch lost adjustment, it could fall off.
What clutch rod did you purchase from NPD, and did it come with both parts?
Old 08-11-2010, 11:01 AM
Im not sure of the part number. I will have to verify. In the NPD catalog it is part number F-7521-7A it is listed for a F100-350 65-72 Lower, 4" original Ford tooling. So I need to verify the length of the one I got. Thanks
Old 08-11-2010, 08:11 PM
thanks for the help. the one they sent me was the wrong one. it was to short. My local napa had one and it works great. Thanks again for the help.
Old 08-11-2010, 10:25 PM
RJP66F100's Avatar
RJP66F100 RJP66F100 is offline
RJP66F100 is starting off with a positive reputation.
Glad you're getting it figured out.
Daveengleson, the spring hooked to the clutch fork would also make sure the throw-out bearing doesn't spin all the time. I know many modern vehicles are made with the throw-out bearing riding the pressure plate fingers all the time but I would want a spring if it was me.
Old 08-12-2010, 10:53 AM
This ole timer does experience an occasional 'senior moment' and can't recall what I did an hour ago moreless 3 yrs ago when I installed a rebuilt engine and replaced the clutch. Got underneath again this a.m. looking for a spring that just aint there, there's no play in the clutch arm and/or adjuster. I may keep too much tention on the adjuster, but as I noted, been this way for past 40yrs. Considered backing off and adding the spring but hesitant, as someone said, 'if it aint broke leave well enough alone'. Anyhow, don't advise anyone to go without said spring, and appreciate the information, perhaps when clutch needs replacing may consider at that time. imagine difficult to determine how many miles to expect out of a clutch, in my case, it's been the family daily driver involving lots of heavy hauling, replaced clutch/bearing 12k's ago and still running strong.
Please help locate part - D7TZ-7534-A 1FastGambler 1973 - 1979 F-100 & Larger F-Series Trucks 11 03-05-2014 09:36 PM
Brake an Clutch petal return spring location KG in CT 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 11-13-2013 08:32 AM
1949 F1 226 Clutch return spring picture Oldbike99 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-12-2013 08:48 PM
Clutch pedal spring 47ky49 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 09-05-2010 11:00 AM
clutch pedal return spring removal? 71 f100 pigdog 1967 - 1972 F-100 & Larger F-Series Trucks 1 01-24-2005 06:49 PM
Tags
1965, 1977, 1980, 96, clutch, f100, f150, ford, lever, release, replace1992, return, rod, spring, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
