You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Can someone tell me the steps on replacing it. Also how should I go about it? Should I go through the top or bottom what do I need to take off to get to it?
drain a/c system. remove fan, fan stator, remove belt from a/c compresser, remove ground cable that is in your way... dont worry you will see it. remove the 3 a/c compressor bolts. position the compresser so you can remove the manifold line, remove the manifold line. reinstall in reverse.
I take them out the top when I do them. Im not an "ac" tech per say but from time to time I help out there too and that how I do the r/i part.
__________________
Former Ford Senior master tech, gas and diesel.1992-2012
ASE Master Tech, L1 certified.
2006 f250 cc swb fx4 6.0
mods arp,egr delete, tuned, 91 gallon RDS fuel tank.
