I'm not thrilled with the Ford Gold coolant. We have heard from International techs that say they change far less oil coolers than Ford Techs. I have heard (read) from several respected owners that have switched to the ELC coolant that International uses. They are very pleased with it.
Is the fact that less oil coolers are changed on International 365s is because they had coolant filters installed early on?
I know of at least one 6.0 that had a coolant filter installed early on and then had oil cooler plugging after several years - 69CJ is one that comes to mind.
We know that under high heat/over heat situations the gold coolant forms precipitates. Is it possible that the gold coolant gets hot enough running through the EGR cooler that it forms precipitates there?
Will those of us with out egr systems still have the same problem?
I have no idea how all of this stuff works so I'd thought I'd ask you all.
__________________
2005 F-250 6.0
Sinister EGR delete, 4" MBRP Turbo Back No Muffler or Cat. Coolant Filter. CCV Mod. Insight Monitor. SCT X3
That is a good question myself and bismic spoke about earlier this week.I flushed my block for about a half hour when my motor was out and apart about 30k miles ago.I have no coolant filter or EGR cooler and work the motor very hard regularly.I was figuring when I drain it this time(might do it this afternoon)if it has chunkies in it that the coolant is breaking down.I do happen to have a case of gold on the shelf so if I drain it I might just run it for 10k and never use it again.I will post in this thread what I find.
__________________
Tony 03/04 6.0L 350 Crew ,DRW,ZF-6, XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. Fass 95/90, Sct X-III with some sweet Spartan tunes, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper,Light Force, Ride-Rite helpers,Ford APCM and some other stuff.
03 6.0L Ex LTD mostly stock
You are correct. I put the filter on at aprox. 2,000 miles. I'm not defending the gold coolant but my system had so much sand in it that the 1st filter plugged at about 300 miles and the 2nd at 1,000 miles. I do have the feeling that my system had so much sand in it from the get go that it was doomed no matter what and yet it made it to over 36,000 before replacing the coolers. If I didn't have a ScanGauge and the info gleened on this and other sites I would probably still have the old coolers in. I never had any puking or outward symptoms. My degas bottle looks new compared to a buddy with 50,000 miles and no filter, no gauges and no problem so far that he is aware of. I would probably consider the elc coolant but I still have a year and a half of bumper to bumper warranty. In my op. the jury is still out but I am listening to all comments that can be substantiated.
__________________
"05 F-250, 6.0, CC, LB, 3.73, 4 X 2, Lariet, with coolant filter and Bilstein shocks, Magnefine p.s. filter, Ford fuel press. spring upgrade and ScanGauge ll. S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k dry weight, 31'
173rd Abn.
I'm interested to hear what you find, as with no egr cooler one would think there shouldn't be any sand. I have a feeling that this is gonna be a hot topic for the near future. I have no evidence of the Ford coolant being an issue as I (like many here) have never experimented with anything else.... Oh well keep on truckin boys
I fail to see the connection between no egr cooler and no sand. If you have sand or precips. the oil cooler will let you know.
__________________
"71 Triumph Trident
173rd Abn.
funny I fail to see a connection between the vt365 and a 6.0. we are we not looking at the many differances that can be causing the lack of failers. programing for one is very different. one is all navastar without fords magic hand in tuning for power.
__________________
Ford Senior master tech, gas and diesel.
ASE Master Tech, L1 certified.
2006 f250 cc swb fx4 6.0
mods arp,egr delete, tuned.
You confused me a little cheezit, can you elaborate?
__________________
"71 Triumph Trident
173rd Abn.
the two engine are close and are in the same family. they use the same block, heads, egr cooler, oil cooler and turbo. the rest of the truck is very different.
the vt 365 is reduced hp and incressed torque. the power bands are very different.
that truck rolls down the road at 1200-1500 rpm. we roll at 1800-2200 rpm.
they run a differnt gear box then the zf or the 5r110.
ford wrote all the softwear for the superduty from 250-500.
the 650/750 wich runs the vt365 is the same set up as navastars vt365. that unit is 100 percent navastar programing.
so what Im really getting at is the fact that the only thing that they have in common is the basic major parts of the engine from there it all changes.
maybe someone that knows more can say if the cam shaft is even the same. I dont know about that one.
__________________
I am going to let the coolant drain into a filter while I go have a few refreshments.Cheezit I understand your point and figure the best test is to change the coolant to international spec and run it the same on that.Who knows it could be clean as a whistle now.We will find out.
__________________
