My 98 XLT 4.6 EXP overhead climate control unit in the front, not the middle. The lights are out, How do you change the blubs, Also I had my heater core replace last week, the front heat blows hot but the middle and rear blows cold, but once I drive it blows luke warm in the rear and when idle it blows cold again. Did anyone every had this issue with your heat, once you had the heater core replace.
